  • Member For: 15y 9m 28d
  On 15/02/2012 at 7:35 AM, mulberry laine said:
78000 Ks,Bought it from melbournes cheapest cars,I know it sounds dodgy but it isnt(I was skeptical).Came with balance of factory warranty plus extended warranty.Chris Morris was the salesmen.
Interesting, Those guys at Melbourne's cheapest cars seem to get a lot of Cop cars in there. I also bought a 04/10 XR6t from Melbourne's cheapest car's and got it shipped up to QLD for an extra 600. Very happy so far, easy to deal with all over the phone. They currently have another 2 listed for ~22k, they are selling them too cheap!
  • Member For: 14y 8m 2d
I went to melbournes cheapest cars and looked at a few in early april this year as I was in the market for one but they were all scuffed up inside and outside yes they were cheap but not for me ended up with a G6ET, there is a place in Granville NSW that sells ex chasers and his ones always seem to be very clean but he had none when I was buying.
  • 2 months later...
  • Bronze Donating Members
  • Member For: 14y 12d
Yeah the ones in Melbourne cheapest cars don't come with rego though and they will give you bugger all trade in on cars too.
Offered me 7k for my BA Turbo when I enquired about a chaser there last year. The FG's interior was shagged too!
Edited by _Velocity_
  • 2 weeks later...
  • New Member
  • Member For: 12y 9m 18d
  On 14/01/2011 at 6:48 AM, Samboc said:
By the way - the Cops serviced the car every 10,000 K.
Better than Ford recommended. Ford recommendations are talked about elsewhere
  On 14/01/2011 at 2:27 PM, Rudiger said:
I think your find regular Fford service as per the book is 15,000. Vicpol cars were oil changed every 5000 and serviced every 10,000. That was the traffic cars (we always looked after them). At stations, the div vans could go beyond that a bit cause they couldn't afford to bring them off the road for a day sometimes, especially if there wasn't a replacement vehicle available.
I bought a 2011 FG XR6T from Pickles auctions a few months ago with 62000kms.
I called up the ford dealer that serviced it and asked about their service schedule for highway patrol cars. They said it was serviced as per the Ford handbook, every 15000kms and brakes were inspected/changed every 5000kms.
When I got it, it had new front rotors and new pads all round. Looks they are some sort of dusty metallic ones like Bendix ultimates maybe.
The second battery in the dual battery setup that comes in these cars is only to run the accessories, it won't help to crank if the primary one fails. It's an optima yellow so it's a good one to replace your standard one.
The car is a little rough around the edges but it's a good buy if you can live with small scratches here and there.
  • Member For: 13y 2m 14d
We used to service fg xrt highway cars every 10000 kms. All Commodores in town now. Oil & filter, diff oil with additive (Nulon not Ford. $40 versus $130) check & record pad & rotor thickness. Replace pads when 3mm or less, rotors if undersized or marked. Pads supplied by police fleet company through Repco (Bendix Ultimates from memory). Well serviced but fleet companies like to use aftermarket (cheaper) parts when they can. Get a different program (tune) from stock. Speed limiter removed, smart alternator charge programming modified to allow full charging all time at idle. Batteries were running flat while cars idled at roadside. No more power as part of ecu program. Program (tune) done on stock Ford workshop computer. Get a flogging but Hot seat changes generally lead to less cold start engine wear. If no obvious damage, gutter jumping etc, Prob pretty good buy, if you want an auto....
Sorry bout such long post...
  • 1 month later...
  • Member For: 14y 6m 3d
Just an update. Have now got 120,000 K on the clock. Only trouble was the water pump pulley coming loose. Replaced under Ford warranty. Have just had the diff bushes replaced under extended warranty. The local Ford dealer feels happier doing a service every 7,500 K. I am happy with that. Used to change my oil every 5,000 k in the past and it keeps the warranty good. Still on the same brake pads since I bought the car. Must be due for a change soon. Also had it's 1st buff and polish. Looking good. The Federals are at 50%. I can not find a reason to buy factory fitted Dunlops. On a score of 0-10 has to be 10+.
