Robos F6 Donating Members 407 Member For: 15y 10m 10d Gender: Male Location: Vic Posted 10/01/11 09:31 AM Share Posted 10/01/11 09:31 AM How does it go with this setup? Link to comment Share on other sites More sharing options...
Kingers. Member 227 Member For: 14y 10m 22d Posted 18/01/11 11:07 AM Share Posted 18/01/11 11:07 AM hey mate how did you secure your battery down? got any pics? Needa move my battery to that side and not sure how to fix it down Link to comment Share on other sites More sharing options...
freeze_dk I am dissatisfied with my current employment situation Donating Members 8,610 Member For: 18y 3m 15d Gender: Male Posted 18/01/11 11:28 AM Share Posted 18/01/11 11:28 AM I had my setup like this for 2 weeks.. then I noticed that the rear breather was leaking oil onto the exhaust shield.. Link to comment Share on other sites More sharing options...
jonn Member 141 Member For: 16y 29d Gender: Male Location: Carrum, VIC Posted 19/01/11 03:01 PM Author Share Posted 19/01/11 03:01 PM yeah easy $800 saving.ill just find a reducer silicon pipe to replace the crossover, wont be the hardest thing ive done.goes well, breaks traction in 2nd just putting the foot down. not 100% sure without a proper dyno but my $200(I didnt pay $200) obd2 program says its pulling 283rwkw now, 263 with the old setup, and when it was tuned it made 265 so.. id say its close.the flex pipe has got a wire curled through it, its a intake flex pipe and its pretty sturdy, wouldnt collapse.ille take some pics of the battery thing for you when I get a chance, hopefully tomorrow. it was quite simple to make, and had to drill a hole in the wheel arch thing to bolt it down to.pics will explain.planning to go a Hdi intercooler very soon, and get silicon to replace that flex pipe for a smoother air flow.gotta keep up with my mates fg somehow Link to comment Share on other sites More sharing options...
01txr Member 861 Member For: 17y 11m 29d Gender: Male Location: QLD Posted 19/01/11 04:37 PM Share Posted 19/01/11 04:37 PM or just replace it with another pipe. Just use the flexy pipe all over the motor! lol.Mind you with the air filter showing like that, you will be defected if they pop the bonnet. Either way, piss to pass.good stuff. Saves you 800$Don't know how the dot laws are down Vic but pretty sure hereIn QLD it's ok. I know that if you had a aircleaner protruding from bonnet old schoolCarb v8 it was illegal, because of emissions as carbs get a fuel vaporAbove carb which could filter through to the atmosphere. Have heard some talk that may be able to get defected due toNoise???Anyway hope it's all ok as havnt made my airbox as yet. John, good to see you trying,do suggest you seal it up as you want to try to have it pressurize as much as it can from theEntering frontal air, not escaping out the top. Becareful with the crossovers as lots have flakes the paintInternally and destroyed turbos. If it has the paint internally, either remove the paint or risk turbo damage. Hard to believe you are getting same intake temps to your friend, are you talkingSitting idling. Or after some hard throttle runs?I know my BA with plaz airbox stand cooler, struggled after burnout toStage, felt so dead on launch when I did show off skids compared to quick turnOf tyres 1st gear. Once I fitted my HDI it solved the oem ic's problem. I went with the HDI GT series 600x300x75 rather then the b series Xr kitAs was told the this particular GT series cooler was a better optionBy the for my power. Since buying it I have up graded to a TO4z setup but only running mild12psi, the Cooler still doing it's job. It may struggle once I put new engine in and up the boost. If it does it will go and a plaz ic will take it's place. I find the HDI to be a ecellent IC for it's dollar so your choice toGo with one should make you happy when you do. You want to keep up with your mates FG, you'll need lots of dollars orSwitch his tune to valet if he has one. Lol Link to comment Share on other sites More sharing options...
jonn Member 141 Member For: 16y 29d Gender: Male Location: Carrum, VIC Posted 19/01/11 05:58 PM Author Share Posted 19/01/11 05:58 PM that was a good read.the intake temps were similar when just driving along, his one cools down much quicker obviously and doesnt heat up as much.its a good theory to box up the pod to keep the cool air in one place ill be making something proper when I get the cooler and silicone pipes. the flexi pipe was never going to be a permanenthow did you get to have a taller wider intercooler? the kits on ebay only have up to 580x285x78the noise isnt a problem, I just dont wind the boost up to 16psi and let it off haha and yes my mates fg is ballistic, and he wants to get semislicks.. couldnt imagine how quick it would go with no wheel spin!anyway thanks for that, hopefully I should see a hdi cooler in the mail soon Link to comment Share on other sites More sharing options...
01txr Member 861 Member For: 17y 11m 29d Gender: Male Location: QLD Posted 20/01/11 02:47 AM Share Posted 20/01/11 02:47 AM Sorry just re measured core and your right. Do they spec this size in the BA-BF kits?Bought mine like near 2 year ago and the Xr one was a smallerCooler and not as good as the GT series one I optioned up to. If that's what they are including now, it's a good option. I trimmed my chassis rails at front edge as the in/out interfered andYou can't fit undertray on if you mount it down lower. Did not affect and chassis integrity as didn't remove the spot weldsHolding rail together. If you want I can post you picture if metal moved, as easy to get to asHave car apart as building new engine. Link to comment Share on other sites More sharing options...
jonn Member 141 Member For: 16y 29d Gender: Male Location: Carrum, VIC Posted 20/01/11 07:51 AM Author Share Posted 20/01/11 07:51 AM yeah it shouldnt be a problemand yea they offer the 580x285 size for the ba/bf xfor 770. or a smaller 580x210 for $660. probably worth $100 more but the top bit of the taller one wont really get the wind into it Link to comment Share on other sites More sharing options...
01txr Member 861 Member For: 17y 11m 29d Gender: Male Location: QLD Posted 20/01/11 08:50 AM Share Posted 20/01/11 08:50 AM It still will work better as the air entering finds the easiest path, only so much can directly go through the rest finds the easier way which will be in the not so direct way. Keep in mind as long as the fins can radiate heat it will be helping even if it's not in direct air flow, just as long as it has room for the heat to dissipate away from it. If you wanted to go to the trouble you run a deflector strip say 50 down from bar support beam to help get air flow through top of cooler, also run shielding over top to stop the flow going over it. Maybe a option for me once I do up the boost before going with a plaz ic. Also I'm going to hook up a water spray setup as well, have pluming and nossles ready just need to find a suitable pump. The nossles I have are just a cheap anti drip irrigation item. Maybe the larger IC option was due partly to me??? As back when they started doing the first kits as I asked them if it would suit my power application and they said It maybe better to try the larger GT Series one and if it didn't fit I could return it. I already had plaz piping so it was just a cooler I purchased. I fitted it and told them about it. Maybe they decided to offer it as a upgrade kit because of my correspondence with them. Yeh those FG's go hard with the HDI kit, just look at that RDP car that ran the 1st 10 with not much else done. Link to comment Share on other sites More sharing options...
brettenator Member 66 Member For: 14y 9d Gender: Male Posted 10/02/11 12:46 PM Share Posted 10/02/11 12:46 PM pulling 283rwkw now, 263 with the old setupForgive my ignorance but is 20kW a usual gain for an air intake mod like this? Link to comment Share on other sites More sharing options...
