gaz097 Bronze Donating Members 1,752 Member For: 13y 7m 11d Posted 14/09/13 11:37 PM Share Posted 14/09/13 11:37 PM . Link to comment Share on other sites More sharing options...
gbp Member 57 Member For: 11y 7d Posted 15/03/14 01:01 AM Share Posted 15/03/14 01:01 AM both turbos have the same rear housing but from what I have read the fg has a bigger different shaped hole and flapper standard? I am interested to see how an original ported ba/bf rear housing would go on a fg turbo front housing...would it even be benificial or are the fg ones better from stock???Is this fact? If I got a FG rear housing would that negate the need for the mod? Link to comment Share on other sites More sharing options...
old_mate Member 767 Member For: 19y 19d Gender: Male Location: Brisbane Posted 15/03/14 03:01 AM Share Posted 15/03/14 03:01 AM You need to do the mod 1 Link to comment Share on other sites More sharing options...
Bomber Carnage on the Garage Floor Donating Members 3,994 Member For: 14y 9m 21d Gender: Male Location: Gold Coast Posted 15/03/14 06:07 AM Share Posted 15/03/14 06:07 AM Has anybody just ported and blended a FG housing without changing the flapper? Link to comment Share on other sites More sharing options...
gbp Member 57 Member For: 11y 7d Posted 15/03/14 06:36 AM Share Posted 15/03/14 06:36 AM Another question, (only because port and mod is quite expensive in NZ) will this work OK with a good wastegate?http://www.trademe.co.nz/motors/car-parts-accessories/performance/turbos/auction-704474352.htmWould I weld the flap closed? Will this also do away with actuator?Seems to solve alot of issues but I've not seen it before so wondering what are the drawbacks (if it will even work at all). Link to comment Share on other sites More sharing options...
ms700 Moderating Team 10,170 Member For: 22y 1m 1d Gender: Male Location: Sydney Posted 15/03/14 07:12 AM Share Posted 15/03/14 07:12 AM that's just a adapter. You will still need to buy a external wastegate. Link to comment Share on other sites More sharing options...
gbp Member 57 Member For: 11y 7d Posted 15/03/14 07:16 AM Share Posted 15/03/14 07:16 AM that's just a adapter. You will still need to buy a external wastegate.Understand mate, as above I said "with a good wastegate" will it work OK It seems like the solution to a big problem, just wondering why it's not pursued more often Link to comment Share on other sites More sharing options...
ms700 Moderating Team 10,170 Member For: 22y 1m 1d Gender: Male Location: Sydney Posted 15/03/14 09:23 AM Share Posted 15/03/14 09:23 AM Umm no need? Its only a big problem to those who make it one.Some guys in here with 500 at the wheels with a internal gated turbo.If its done properly ie not cutting corners, internal gates work fine, and flow plenty. Link to comment Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,752 Member For: 13y 7m 11d Posted 15/03/14 12:30 PM Share Posted 15/03/14 12:30 PM I doubt the turbo will still fit with that spacer. Its tight as is then add 30-40mm and she will be hard against the upright. Porting the gate is easy really. I done mine with Die grinder and welded a flapper on with no issues. Went from a minimum of 17psi up top to tapering 18 down to 16psi 1 Link to comment Share on other sites More sharing options...
Wenier Donating Members 1,736 Member For: 15y 1m 14d Gender: Male Location: Christchurch, New Zealand Posted 16/03/14 12:24 AM Share Posted 16/03/14 12:24 AM Another question, (only because port and mod is quite expensive in NZ) will this work OK with a good wastegate?http://www.trademe.co.nz/motors/car-parts-accessories/performance/turbos/auction-704474352.htmWould I weld the flap closed? Will this also do away with actuator?Seems to solve alot of issues but I've not seen it before so wondering what are the drawbacks (if it will even work at all).The fact your doing mods and the tuning costs money, it isn't really expensive when compared with overall costs. Link to comment Share on other sites More sharing options...
