  • Member For: 14y 3m 27d
How big is the hole to begin with?
I've got a turbo that's been modded, has a 37 or 38mm flap, but only a 30mm hole.
Also I noticed alot of cracks in around the port - its a ford rear housing. Is cracking in this area okay or going to cause problems?
  • Member For: 15y 3m 19d
You do have a lot of crack there. Bad part is they will keep working and getting bigger.
So, if its left as is, what problems can it cause, as its obviously just going to get worse.
At the moment that's the only cracks I can see in it - none around the bolt holes.
  • 3 months later...
  • Member For: 16y 4m 29d
excuse my ignorance, I had a look through how you did it but I couldnt see any exact measurements, I am also at work and the pictures are being gaaaaaaaay... would a 30mm port be enough to control boost at say 350+kw???
  • Member For: 18y 11m 12d
When you port the housing the wastegate exit, It will be ovaled not round. Due to the height restrictions of the upper and lower floor you can only take until it is level. So you then extend the port horizontally.. Once you have the housing in your hand you'll see what I mean.
  • Member For: 19y 4m 19d
Anyone come accross the larger flapper catching on the port and the way around it ?
