conrad Donating Members 40 Member For: 15y 11m 4d Gender: Male Location: In the Worksop Drinking Beer Posted 06/01/11 06:52 AM Share Posted 06/01/11 06:52 AM I've just purchased a flapper (37mm, Garret Part Number 774184-0001) from MTQ in Perth, for the wastegate mod on my XR6T. What I would like to know is what should the housing be ported out too (How Many Millimetres)CheersConrad Lovett Link to comment https://www.fordxr6turbo.com/forum/topic/72539-turbo-waste-gate-flapper-mod/ Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 7m 20d Gender: Male Location: Perth Posted 06/01/11 07:05 AM Share Posted 06/01/11 07:05 AM 1.5/2mm overlap between the port and the flapper will suffice. To get the best out of the unit you need too smooth the wastgate hole and do a little finessing to direct the gases correctlyI'd suggest if possible you get Simon from XFT too open it up for you. He has some little tricks that help too prevent the dreaded boost spike. Link to comment https://www.fordxr6turbo.com/forum/topic/72539-turbo-waste-gate-flapper-mod/#findComment-1069554 Share on other sites More sharing options...
conrad Donating Members 40 Member For: 15y 11m 4d Gender: Male Location: In the Worksop Drinking Beer Posted 06/01/11 07:09 AM Author Share Posted 06/01/11 07:09 AM Cheers mate for the fast response, I will do the mod myself, I have ported and polished heads before so this should be no real biggie, I have a thickness tester so I can monitor the thickness of the housing walls as I do the porting. Once again thanks for your help.Conrad Link to comment https://www.fordxr6turbo.com/forum/topic/72539-turbo-waste-gate-flapper-mod/#findComment-1069556 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 7m 20d Gender: Male Location: Perth Posted 06/01/11 07:15 AM Share Posted 06/01/11 07:15 AM No worries mate. when you carry out the work, have a think about the direction the gas is travelling when it exists the manifold and wants too head out the wastegate. This should give you a pretty good idea of the areas that need blending/smoothing. Link to comment https://www.fordxr6turbo.com/forum/topic/72539-turbo-waste-gate-flapper-mod/#findComment-1069559 Share on other sites More sharing options...
HI PSI Member 1,589 Member For: 18y 11m 19d Gender: Male Location: Central Queensland Posted 06/01/11 09:46 AM Share Posted 06/01/11 09:46 AM You can find previous threads about the porting quite easily here on Xr6Turbo.Here is a link discussing the porting and what needs to be done. It even has pictures of the housing that I ported myself...Read my posts in another thread..... Porting the housingBe sure to read the pages below also.. There are many words of wisdom in there ......Removal of Turbo In Prepeartion of Porting Part 1Removal of Turbo in Preparation of Porting Part 2 Link to comment https://www.fordxr6turbo.com/forum/topic/72539-turbo-waste-gate-flapper-mod/#findComment-1069632 Share on other sites More sharing options...
conrad Donating Members 40 Member For: 15y 11m 4d Gender: Male Location: In the Worksop Drinking Beer Posted 06/01/11 10:12 AM Author Share Posted 06/01/11 10:12 AM Cheers bud I will take all of this into account when I go ahead with the mod, thanks for your help. If only some one would sell me a housing to do the mod on. I'm sure something will come up.CheersConrad Link to comment https://www.fordxr6turbo.com/forum/topic/72539-turbo-waste-gate-flapper-mod/#findComment-1069642 Share on other sites More sharing options...
Panda Eyes flame magnet Gold Donating Members 5,674 Member For: 16y 11m 27d Gender: Male Location: adelaide hills- 'race air' central Posted 06/01/11 11:06 AM Share Posted 06/01/11 11:06 AM what did the flapper set you back? Link to comment https://www.fordxr6turbo.com/forum/topic/72539-turbo-waste-gate-flapper-mod/#findComment-1069679 Share on other sites More sharing options...
HI PSI Member 1,589 Member For: 18y 11m 19d Gender: Male Location: Central Queensland Posted 06/01/11 11:37 AM Share Posted 06/01/11 11:37 AM Quote what did the flapper set you back? I purchased a new flapper and bush together.. As my bush broke when I tried to remove it...From memory it was around $120 for both... See Ratter here on the forums. He can supply them at a better price.. Quote If only some one would sell me a housing to do the mod on. I'm sure something will come up.Good housings are VERY hard to find.. As they all crack where the turbo bolts together... Upon close inspection my original housing was shagged also..... It is now used as a door stop...... I wish you luck with your search... Link to comment https://www.fordxr6turbo.com/forum/topic/72539-turbo-waste-gate-flapper-mod/#findComment-1069706 Share on other sites More sharing options...
conrad Donating Members 40 Member For: 15y 11m 4d Gender: Male Location: In the Worksop Drinking Beer Posted 06/01/11 01:09 PM Author Share Posted 06/01/11 01:09 PM On 06/01/2011 at 11:06 AM, fordriver1 said: what did the flapper set you back?MTQ have the flapper for $37+Postage, if you ask them nicely they will just send it for free in an envelope. I rang MTQ in Perth and spoke to Tristan in the turbo parts, just google search them and your set.Conrad Link to comment https://www.fordxr6turbo.com/forum/topic/72539-turbo-waste-gate-flapper-mod/#findComment-1069732 Share on other sites More sharing options...
conrad Donating Members 40 Member For: 15y 11m 4d Gender: Male Location: In the Worksop Drinking Beer Posted 23/01/11 07:15 AM Author Share Posted 23/01/11 07:15 AM Good as wood ported the housing out to 32mm and left a min of 1mm overlap. I have another housing that I will port and do the flapper mod to, within the next 2 weeks, if anyone is interested PM me for price.CheersConrad Link to comment https://www.fordxr6turbo.com/forum/topic/72539-turbo-waste-gate-flapper-mod/#findComment-1074913 Share on other sites More sharing options...
