Widest 19" Rim On The Front
Led Ft
  • Member For: 17y 2m 1d
bout to get a set of volk gtc 2 piece wheels of my mate
19x10.5 295 +38 rear
19x 9.5 front
pritty sure the rears will fit .
but im not sure about the fronts
was the widest rim and tire fit some one has done, even modifying the control arms (aftermarket) to suit the rim
help please
  • <put funny sh*t here>
  • Member For: 18y 4m 13d
my front is running 19x8.5 with 245 rubber and its very low, and there is enough clearance. I then spaced the front rims out 4mm with a custom spacer, and under heavy cornering at the track it touches the outside guard just a little bit (not rolled).
  • Member For: 15y 9m 20d
Ive got 18x9.5 on the front and they're a tight fit, with 19's I think you'll have to pump the front guards depending on tyre selection and ride height. What offset are the 19x9.5?
the rear is +38 but I dnt think its the same . I think it might be like 20? dunno yet .
are there any aftermarket uppercontrol arms if the wheels dont fit?
  • A much better forum
  • Member For: 16y 7m 27d
You'll need +20 fronts to clear upper control arm on inside...
And you'll have to pump the guards a bit if you don't want constant scraping...
Test fit the 19x10.5+38s first, the edge of the rim may foul on the inside suspension arms.
sorry I forgot to mention its in a ute, I believe it will fit no trobles
  • Get It To Wheelspin Uncontrolably Then Give It Another 5 Pounds
  • Cruise Control
  • Member For: 14y 5m
let us know how u go with the rears... im keen to try 295's (currently 275's). but I dont wanna roll guards.
