LukesF6 Donating Members 28 Member For: 16y 3m 10d Gender: Male Location: Brisbane Posted 05/01/11 09:10 AM Share Posted 05/01/11 09:10 AM Hi guys... Just wondering if anyone out there has either removed or hollowed out their cat... Power wise does this make much difference... I got an xforce exhaust and the 200cell cat is flanged at each end so Im thinking bout making up a straight through pipe for drags, dyno days, etc... Anyone got any info on this...? Cheers... Link to comment https://www.fordxr6turbo.com/forum/topic/72507-cat-or-no-cat/ Share on other sites More sharing options...
bjc Donating Members 2,823 Member For: 21y 8m 15d Gender: Male Location: Townsville Posted 05/01/11 10:37 AM Share Posted 05/01/11 10:37 AM Yep, I have the xforce single 3.5in and had a local exhaust guru make me up the straight through pipe with the flanges for $100 fitted. I have since had the car semi tuned with the cat still out and I would like to think it flows better, how much I do not know but if someone wants to throw money at me for two dyno runs and change of cat (cat is only 10min job anyway, unless your on ramps then a near broken eye socket came my way!lol) I will gladly run my car up and see.Mine is a 03 BA Auto. Another thing to replace if you haven't read it on here is the rear muffler to a single straight through as the twin tip is restrictive and was 2-3psi on my car worth of restriction.Either way I'd say no cat as the noise is marginally different and no one would ever know unless crawling on the ground! Link to comment https://www.fordxr6turbo.com/forum/topic/72507-cat-or-no-cat/#findComment-1069310 Share on other sites More sharing options...
icer Banned 2,335 Member For: 15y 10m 1d Gender: Male Location: Aspendale, Vic. Posted 05/01/11 11:00 AM Share Posted 05/01/11 11:00 AM just get a race 100cell cat. they flow 500+rwkw.otherwise you will fail EVERY EPA emissions test you go to and possible risk of a 10,000$ fine for running no CAT.But yes, you get big advantages with a hollow cat/hiflow cat. Link to comment https://www.fordxr6turbo.com/forum/topic/72507-cat-or-no-cat/#findComment-1069327 Share on other sites More sharing options...
Stazza_Brendan Donating Members 686 Member For: 15y 7m 7d Gender: Male Location: Mackay QLD Posted 05/01/11 11:02 AM Share Posted 05/01/11 11:02 AM Does a 100cpsi cat meet EPA though? Link to comment https://www.fordxr6turbo.com/forum/topic/72507-cat-or-no-cat/#findComment-1069329 Share on other sites More sharing options...
LukesF6 Donating Members 28 Member For: 16y 3m 10d Gender: Male Location: Brisbane Posted 05/01/11 12:38 PM Author Share Posted 05/01/11 12:38 PM Already have removed rear muffler and replaced it with a straight through pipe and made 8-10kw more...I won't be driving on the road with no cat and I'm pretty sure that u need 200cell to stay legal...I just wanna straight through pipe that I can bolt in and out for events and the like...Would it require a retune though...? Link to comment https://www.fordxr6turbo.com/forum/topic/72507-cat-or-no-cat/#findComment-1069374 Share on other sites More sharing options...
LukesF6 Donating Members 28 Member For: 16y 3m 10d Gender: Male Location: Brisbane Posted 05/01/11 12:41 PM Author Share Posted 05/01/11 12:41 PM On 05/01/2011 at 11:00 AM, icer said: just get a race 100cell cat. they flow 500+rwkw.otherwise you will fail EVERY EPA emissions test you go to and possible risk of a 10,000$ fine for running no CAT.But yes, you get big advantages with a hollow cat/hiflow cat.Holy sh*t 10k... Didnt know the fine was that hefty... Link to comment https://www.fordxr6turbo.com/forum/topic/72507-cat-or-no-cat/#findComment-1069375 Share on other sites More sharing options...
icer Banned 2,335 Member For: 15y 10m 1d Gender: Male Location: Aspendale, Vic. Posted 05/01/11 01:16 PM Share Posted 05/01/11 01:16 PM I had a hollow cat when I got the BA EPA and I passed with deka 60's, AVO intercooler kit, and I had to swap my hollow cat with a 100cell VENOM cat of ebay. It passed after I ONLY swapped the cat. I still run the VENOM now. Link to comment https://www.fordxr6turbo.com/forum/topic/72507-cat-or-no-cat/#findComment-1069384 Share on other sites More sharing options...
bjcrown Donating Members 182 Member For: 19y 6m 29d Posted 05/01/11 09:59 PM Share Posted 05/01/11 09:59 PM My car is stock BUT is tuned. Would I require a re-tune if I was to replace the cat with a higher flowing cat? Link to comment https://www.fordxr6turbo.com/forum/topic/72507-cat-or-no-cat/#findComment-1069428 Share on other sites More sharing options...
Wenier Donating Members 1,736 Member For: 15y 4m Gender: Male Location: Christchurch, New Zealand Posted 05/01/11 10:26 PM Share Posted 05/01/11 10:26 PM You would need to check whether the AFRs have changed or not. Generally the loss of that small bit of back pressure would mean you should. Link to comment https://www.fordxr6turbo.com/forum/topic/72507-cat-or-no-cat/#findComment-1069432 Share on other sites More sharing options...
