SuckSqueezeBangBlow ʎǝʞuoɯ ɹoıuǝs Donating Members 1,808 Member For: 16y 4m 26d Gender: Male Posted 03/01/11 03:59 AM Author Share Posted 03/01/11 03:59 AM might try that next time.whats the bottom pic of? Link to comment https://www.fordxr6turbo.com/forum/topic/72459-zf-heat-exchanger-replacement/page/2/#findComment-1068629 Share on other sites More sharing options...
XF Falcon <put funny sh*t here> Member 3,365 Member For: 18y 6m 3d Gender: Male Location: Perth, NOR Posted 03/01/11 06:02 AM Share Posted 03/01/11 06:02 AM the inner guard liner with a hole cut out and some mesh in its place, to let air flow through there better. the cooler is in front of that I believe. Link to comment https://www.fordxr6turbo.com/forum/topic/72459-zf-heat-exchanger-replacement/page/2/#findComment-1068661 Share on other sites More sharing options...
adrian_celati Donating Members 82 Member For: 16y 4m 2d Gender: Male Posted 07/10/11 10:59 AM Share Posted 07/10/11 10:59 AM Thinking of doing this soon. Most auto transmission places say that the heat exchanger should be changed every 100k as they corrode. Did much coolant come out when you did this? How did you stop the coolant and ATF from coming out?Cheers. Link to comment https://www.fordxr6turbo.com/forum/topic/72459-zf-heat-exchanger-replacement/page/2/#findComment-1147227 Share on other sites More sharing options...
sc s15 New Member 16 Member For: 20y 4m 19d Gender: Male Location: Brisbane Posted 31/10/11 06:24 AM Share Posted 31/10/11 06:24 AM Sorry to dig up an old thread...Does anyone have the part no. for the bigger heat exchanger? I do a fair bit of heavy towing and wouldn't mind upgrading. Ford always want the VIN number when ordering parts. Link to comment https://www.fordxr6turbo.com/forum/topic/72459-zf-heat-exchanger-replacement/page/2/#findComment-1155318 Share on other sites More sharing options...
SuckSqueezeBangBlow ʎǝʞuoɯ ɹoıuǝs Donating Members 1,808 Member For: 16y 4m 26d Gender: Male Posted 01/11/11 11:01 AM Author Share Posted 01/11/11 11:01 AM u can see the part number in the 4th pic in post #1. Link to comment https://www.fordxr6turbo.com/forum/topic/72459-zf-heat-exchanger-replacement/page/2/#findComment-1155680 Share on other sites More sharing options...
hunty New Member 7 Member For: 12y 29d Posted 01/02/23 04:59 AM Share Posted 01/02/23 04:59 AM On 02/01/2011 at 4:41 AM, SuckSqueezeBangBlow said: yep, KTM. no, not much fluid lost - less than cup, went for a drive and its shifting the same. however, I'm going to do another service fill of the box next week anyway. sorry mate no idea. also, I'm only going by what the ford parts guy said when he looked it up on his computer in that the r-spec and territory one are the same. if someone else could confirm it to be true or BS that would be good. Expand So I was going to ask if you got from a third party supplier or ford."Ford Parts guy" answers that I guess. Some dealers are saying 'no stock' at the moment. So maybe it is an Air to fluid cooler I need at the moment. (its preventative , not disaster (yet). Link to comment https://www.fordxr6turbo.com/forum/topic/72459-zf-heat-exchanger-replacement/page/2/#findComment-1717004 Share on other sites More sharing options...
