  • Member For: 14y 9m 26d
Zayd687 I have a 300rwkw car which uses less fuel then when it was stock my mate has 320rwkw using the same amount as when it was stock.
  • 1 month later...
  • Replies 89
  • You've changed man....
  • Member For: 14y 4m 26d
Well I have purchased most the stuff I need and she is booked in to see Mick at Pitlane 18-19th feb.
Parts chosen are:
PWR stepped cooler $900
Herrod Pipe kit $410
Xforce 4" Dump $410
Outlaw 5" Cat $345
Nizpro Injectors $711 (fitted by Pitlane)
XCAL 3 $722
Tune by Pitlane $727
all prices exc. GST.
On top of that I am fabricating my own 4" intake, airbox and battery relocation kit.
It fits a K&N Pod 6">5" x 9 1/2" long.
Still to come:
Fabricating my own cat back, I have plenty of 4" stainless tube and bends at my disposal so will be going 4" right through. But I might split into two 3" tips at the rear muffler.
Muffler Choice:
Middle Muffler:
Rear Muffler:
same as above
or
What are your thoughts?
If there is droning I could possible slip one of these in to help get rid of it?
  On 07/01/2011 at 7:39 AM, R-SPEC said:
You'll need to port the wastegate and put a larger flap on there to control the boost.
So R-SPEC, I will need to do that with a full 4" zorst?
Option b) is to use the 4-3" split as middle muffler then run twin 3" but didnt want to buy an extra muffler if I could get out of it. I suppose Magnaflow would have a twin 3" in twin 3" out muffler?
It will be routed the same way as stock up to the middle muffler. Only difference from there when it goes over the diff it wont go back down. It will comtinue up over the chassis and run straight out from there.
There will be roughly 6 1/2" between top of chassis to underneath of tray. Oh yeah if anyone didnt know the tub is comin off and custom tray is goin on. see my other thread in ute section.
Or what are thoughts on this option (excuse my paint skills, glad my welding is better than that)
Middle muffler is 4" in to split 3". Then rear mufflers are 3" in to split 3 or 2 1/2". Would there be a problem with that set up because the pipe on left of pic is much longer than the right? Also would 3" into twin 3" at the tips create a horrible fart noise?
Edited by S3XR6T
  • Member For: 17y 11m 27d
What next year?
april
Thanks Dills... very helpfull :fool:
Edited by S3XR6T
  • Member For: 16y 4m 21d
Correct me if I am wrong here anyone... But this is a manual! An it has a stock clutch.... Well sorry to burst Anyones bubble! And unless ive been under a Rock since the FG's came out... Surley the stock clutch will not handle 300+rwkw.... When I just had my flash tune, which made like 240rwkw.... My stock clutch died after 2 weeks in my BA... I'm a pretty hard launcher and driver but still points out the fact if u intend on doing 1/4 your Clutch will not hold up! I got a malwood option 3 for my new tune I did! After my tune I made 326rwkw and soon getting a 16/17psi tune and then an 20ltr E85 tune... My clutch is holding up perfectly!! Apart from slave cylinders dying. But yeh just a heads up I hope you take into consideration the clutch man.... But good luck! And have fun with your new beast! :)
Im not sure myself but I rekkon it would of been mentioned to me before now, between my tuner and all the guys here with 300+
Ill just put some coin away for Justin Case I need to git me a MW :)
whats the $$ of an option 3?
Sooooo.... Quads anyone???? I really need the zorst sorted as am ready to order the muffs asap...
Edited by S3XR6T
Also if I do the wastegate/flapper, what should I get done and how much $$?
I have a turbo off a BF typhoon that the bearing are rooted on, could any of that be salvaged for later mods to get to 350kw?
I got over 300atw and my clutch is fine, no slipping at all, had this power for about 3 or 4 months now.
