STAINLESS again plz You've changed man.... Donating Members 8,142 Member For: 14y 4m 26d Gender: Male Location: 2 Fuchsia Court, Narre Warren. 3805 Posted 04/01/11 09:07 AM Author Share Posted 04/01/11 09:07 AM On 04/01/2011 at 12:28 AM, MiKa said: Hey Ben, that turbo upgrade is just to control boost better.. You'd have to change your turbo to a BA/BF one so yea more expensive.. You might be able to change your turbo housings/internals but im not sure..Depending on the driver, but 12's is the norm for manuals, other than Spiro's freak machine, I think the next 'normal' quickest manual is like a high 11?Good luck with it dude, and yea I'd be waiting for Mick to get back..Cheers Mike.thanks for the info...think ill just stick with 320ish rwkw for a wile On 04/01/2011 at 12:33 AM, Dillz said: Looks about right, I assume your fitting all the gear yourself? And Rapid sells full 4inch XForce systems for $1400 so that would save you $600.Prob just get it all installed at pit lane.Is the xforce 4" for utes also? Link to comment https://www.fordxr6turbo.com/forum/topic/72447-advice-on-new-upgrades/page/5/#findComment-1069019 Share on other sites More sharing options...
STAINLESS again plz You've changed man.... Donating Members 8,142 Member For: 14y 4m 26d Gender: Male Location: 2 Fuchsia Court, Narre Warren. 3805 Posted 04/01/11 09:10 AM Author Share Posted 04/01/11 09:10 AM On 04/01/2011 at 12:39 AM, j.d said: you can get a intake replacement pipe from plazmaman for $195 cheaper then rapids $210https://www.plazmaman.com/shop/index.php?action=item&itemId=364Very nice... Thanks j.d On 04/01/2011 at 2:19 AM, icer said: check the for sale section here. Fair few power upgrades in good condition items for sale. Save you a fair bit of coin.Have been and will continue to thanks ice On 04/01/2011 at 8:36 AM, kizzaF6 said: What about the stock clutch? with all this new found power surely it isn't going to handle it? if it was me I'd factor in $1800ish for a Mal wood option3+.havnt read anythin yet about stock clutch needin upgrade to handle 320ish...Pretty sure itll handle it...Someone please correct me if im wrong... Link to comment https://www.fordxr6turbo.com/forum/topic/72447-advice-on-new-upgrades/page/5/#findComment-1069022 Share on other sites More sharing options...
Dillz Three pedals are better then two.. Donating Members 15,637 Member For: 17y 11m 27d Gender: Male Location: Melbourne Posted 04/01/11 09:15 AM Share Posted 04/01/11 09:15 AM On 04/01/2011 at 9:07 AM, S3XR6T said: Prob just get it all installed at pit lane.Is the xforce 4" for utes also?I'd ssume so, you'd have to check with them. Link to comment https://www.fordxr6turbo.com/forum/topic/72447-advice-on-new-upgrades/page/5/#findComment-1069023 Share on other sites More sharing options...
Duffman Donating Members 129 Member For: 15y 11m 27d Gender: Male Location: New Zealand Posted 04/01/11 09:35 AM Share Posted 04/01/11 09:35 AM what about valve springs? or are fg stock ones fine for ~350kw? Link to comment https://www.fordxr6turbo.com/forum/topic/72447-advice-on-new-upgrades/page/5/#findComment-1069032 Share on other sites More sharing options...
STAINLESS again plz You've changed man.... Donating Members 8,142 Member For: 14y 4m 26d Gender: Male Location: 2 Fuchsia Court, Narre Warren. 3805 Posted 04/01/11 10:04 AM Author Share Posted 04/01/11 10:04 AM On 04/01/2011 at 12:33 AM, Dillz said: Looks about right, I assume your fitting all the gear yourself? And Rapid sells full 4inch XForce systems for $1400 so that would save you $600.Hey if I fit it all myself would it be ok to drive from keysborough to Pit Lane in Frangga without bein tuned? Link to comment https://www.fordxr6turbo.com/forum/topic/72447-advice-on-new-upgrades/page/5/#findComment-1069049 Share on other sites More sharing options...
Dillz Three pedals are better then two.. Donating Members 15,637 Member For: 17y 11m 27d Gender: Male Location: Melbourne Posted 04/01/11 10:08 AM Share Posted 04/01/11 10:08 AM Probably not, wouldn't risk it anyway. Link to comment https://www.fordxr6turbo.com/forum/topic/72447-advice-on-new-upgrades/page/5/#findComment-1069054 Share on other sites More sharing options...
icer Banned 2,335 Member For: 15y 10m 6d Gender: Male Location: Aspendale, Vic. Posted 04/01/11 10:13 AM Share Posted 04/01/11 10:13 AM if you baby it down with no boost you should be fine.AFAIK the only thing you worry about without babying the car to tuner, is injectors. Rest of mods you can cruise with no boost down.Else, tow it down for a safe option. Link to comment https://www.fordxr6turbo.com/forum/topic/72447-advice-on-new-upgrades/page/5/#findComment-1069058 Share on other sites More sharing options...
STAINLESS again plz You've changed man.... Donating Members 8,142 Member For: 14y 4m 26d Gender: Male Location: 2 Fuchsia Court, Narre Warren. 3805 Posted 05/01/11 05:15 AM Author Share Posted 05/01/11 05:15 AM Car trailer it is then... Link to comment https://www.fordxr6turbo.com/forum/topic/72447-advice-on-new-upgrades/page/5/#findComment-1069240 Share on other sites More sharing options...
R-SPEC You are a dead set goose Silver Donating Members 3,968 Member For: 19y 5m 23d Gender: Male Location: Melbourne Posted 07/01/11 07:39 AM Share Posted 07/01/11 07:39 AM (edited) You should get a full stainless steel exhaust. Bestmuffler sell them for $1690, full stainless 4" XForce exhaust.You'll need to port the wastegate and put a larger flap on there to control the boost. But you can get mid 300's without doing the intake at all. Just change the pipes over to avoid them splitting with the higher boost. That would save you money and keep you closer to your budget. Or you could pick up a battery relocation kit for $395 and an airbox for $495 which is a similar cost to the other parts you listed, but you'd get a sh*tload more response with the airbox and 4" intake straight off the turbo. So I think you should do this:PLAZMAMAN airbox & intake - $495 Battery reloc kit - $395PWR Stepped Cooler - $990Herrod Pipe Kit - $4504" full zorst - $1690Injectors - $450X3 - $795Custom tune by Mick@PitLane - $800$6515BUT if I were you I'd spend the $795 for the X3 on getting the wastegate ported. X3's are a waste of time, just get the tune flashed into the PCM and keep it in there!If this is too expensive just get rid of the intake and do the piping so take off $890 so $5625 Edited 07/01/11 07:43 AM by R-SPEC Link to comment https://www.fordxr6turbo.com/forum/topic/72447-advice-on-new-upgrades/page/5/#findComment-1069944 Share on other sites More sharing options...
Worm A much better forum Silver Donating Members 3,808 Member For: 16y 10m Gender: Male Location: Victoria Posted 07/01/11 08:38 AM Share Posted 07/01/11 08:38 AM His not as dumb as he looks... Link to comment https://www.fordxr6turbo.com/forum/topic/72447-advice-on-new-upgrades/page/5/#findComment-1069970 Share on other sites More sharing options...
