  • Member For: 17y 11m 26d
Welcome to the forum Ben, you should easily be able to get over 300 for 5-6k. Choosing what gear you want to use will be the hardest part, those power cooler kits seem to be around the same price as everyone else so I'd have alook at the other options out there too before choosing.
Good luck with it all.
  • Replies 89
  • You've changed man....
  • Member For: 14y 4m 25d
Thanks Dillz.
The thing I like bout the PWR is no cutting of car needed and the Herrod pipe kit seems like good value and plumbs
straight into it.
  • flame magnet
  • Member For: 17y 6d
AFF is australian ford forum, dude! :spoton:
So this is what I'm lookin at now...
PLAZMAMAN INTAKE $595
Replace Intake Pipe(rapid) $210 just for the spool noise
PWR Stepped Cooler $990 no cutting required
Herrod Pipe Kit $450 no cutting required
4"Full zorst+5"HiFlow cat $2000 hopefully cheaper
Injectors From $450
X3 $795
Custom tune by Mick@PitLane $800
Its over my $5k budget by $1200 but oops... :sold:
Pretty sure that will see 320+rwkw.
as far as more than 320rwkw
will throwing this in get me to 350+rwkw?
Or is more extensive turbo upgrade needed?
Turbo Exhaust Housing Upgrade 1
  • Exhaust housing porting
  • 38mm Swing Valve fitted
  • 10, 12 0r 15psi actuator fitted
I may have the bug already guys...
P.S. What would a 6sp manual fg turbo ute with around 320rwkw do down the quarter roughly? 12's? or is that enough to break into 11's?
Would 350rwkw do 11's?
Edited by S3XR6T
  • Member For: 18y 9m 1d
Hey Ben, that turbo upgrade is just to control boost better.. You'd have to change your turbo to a BA/BF one so yea more expensive.. You might be able to change your turbo housings/internals but im not sure..
Depending on the driver, but 12's is the norm for manuals, other than Spiro's freak machine, I think the next 'normal' quickest manual is like a high 11?
Good luck with it dude, and yea I'd be waiting for Mick to get back..
Cheers Mike.
Looks about right, I assume your fitting all the gear yourself? And Rapid sells full 4inch XForce systems for $1400 so that would save you $600.
  • Member For: 14y 9m 25d
you can get a intake replacement pipe from plazmaman for $195 cheaper then rapids $210
https://www.plazmaman.com/shop/index.php?action=item&itemId=364
Edited by j.d
