Fg 20X10 Staggered Wheels
bowie
  • Member For: 16y 10m 27d
looking at getting a set of 20s for the g6et what offset and tyres are people running want to get something big on the arse end any help guys ?
Edited by bowie
20x10 +36, will sit flush with gaurds, may need a little work but will still give a fair ammount of inner clearance.
did you have to get your guards rolled ? what size rear tyre ? I dont think I want to actually do any body work to fit them in
Guest XR09
  • Guests
On the front it's the upper control arm that is the worry with 20" rims on a FG with a 35 offset. A few have done it but have had to go a 235 tyre. Unless you fit a 5mm spacer then you can go a 245. And don't forget if you want it to turn in, you will want some neg camber.
On the rear you can go a 275 on a 9 1/2" rim with a 38 offset no worries. That will sit right with the guards. And yeah there is no lip so all good.
  • Sandtrap Motorsport
  • Member For: 16y 1m 17d
to reply to your profile comment,
specs are 19x10 +10 and 19x10.5 +23
the fronts fit great with 245/40/R19 tyres with rolled guards, but I have a lot of camber.
the rears stick out the guards as I dont have camber kit in the rear yet.
honestly I suggest you DON'T use my wheel specs, as there is a large chance it isnt the look you will want or are chasing.
  • G666E Turbo!!!
  • Member For: 14y 11m 26d
Specs on the wheels depend if you want rubbing or not
Me and a workmates both have fg's his rubs mine does not, mine is also quite a bit lower tucking tyre all around, mine also does not rub when there is 5 people in it and it's tucking rim in the rear.... But my rears are 9.5" with 275's the 10" wouldn't go on they just hit the guards , I have. Custom rear off set so it fits nicely and still looks good... The front you really need a +20 or +25 any higher and it looks gay like mine did until I took the rims back and got the 25 offset..
