The New Addition T04Z And 0.70 Housing
spoolxr6
  • Replies 64
Posted Images
  • 4 weeks later...
  • Member For: 14y 3m 9d
Yeh I did probably about 7 weeks ago now when the weather was hot and it ran crap. Best ET was 12.2 with 116mph. The car feels totally different now that the weather has got colder again so I'll go down again when I get my hands on some semis.
  • Member For: 17y 2m 7d
GCG charge 2150 on average for the mod not including a .70 comp housing they just high flow it and do flapper mod and put a 66mm wheel in. im have just sent mine to them but im thinkin I want the .70 but they are tryin to talk me out of it. claiming its laggy. mabye they dont want to do it. im having trouble getting in contact with mtq turbo does anyone have a ph no
  • Moar Powar Babeh
  • Member For: 19y 5m
http://www.mtqes.com.au/locations.php
MTQ (perth) charged me $2450 In gst for a new core modded too suit the t04Z cover,New exhaust housing with ported wastegate with larger flapper and .07 comp cover. For and extra 300 over the GCG price i'd go for the New unit then sell off your old one too recover some $'s (as I did)
i did have problems with boost control due too the porting method used on the wastegate, and the the fact the it was initially adjusted too crack open @ 18psi(!!!:nukem:!!!) I reported the wastegate and adjusted the cracking pressure down too aprox the wastegate spring pressure and now its all good.
I dont find mine too be laggy at all. It also gives a much smoother transition onto boost. As I've mentioned before I can easily see 18+psi @ 3k in 4th gear (manual) which is on par if not better than the stock 3582R (bearing in mind my boost control is limiting the boost too the level.) I could probably see 20+ if I wanted too
