Fg Custom Tray Build
STAINLESS again plz
  • You've changed man....
  • Member For: 14y 21d
ok so heres actual build progress pics... no more fancy renders.
rear corners...
took me a bit of consideration between using mig or tig.... went with mig
weld material showing :( need a plan b
definately will need plan b
thought I just polish up a corner to see what final result will look like...
can see weld material...
decided to cut the weld back out and reweld with tig... the material showing after polishing was because it was different grade aluminium in the mig wire.
so to attempt to remedy this I have cut some 2mm strips off ally sheet and using that as filler wire for the tig welds...
ps. the side shown in all these pics will now be the underneath side...
now flipped over and using tig to do the top side :)
staggered tig welds to try keep heat/distortion to a minimum
front corners now... tighter radius than the rear so as to match the cabbin...
now assembling the frame....
the join is right where I have to cut out to put the tubs in... so there will be no join...
notched out to clear the back of the led strip taillights...
now comes the tricky stuff.....
method to the madness???
wtf have I got myself in for?
  • Turboless
  • Member For: 13y 10m 21d
About time you updated this thread :P
Have you grinded/polished back any of the tig welds to see if there's a noticeable difference with the welds? Would be good to see some pics of that
Also looks like you're in for some fun welding the tail light surrounds haha
Good stuff keep it up master welder :)
I did a test weld using the method I mentioned above and polished it... came up 99%
compared to before
Edited by STAINOnegger
  • Turboless
sh*tcheah! Can just see the welds but fck me, alot better and probably invisible to the everyday person. Will be good to see how it goes judging at some shows, cos you will won't ya :yes: haha
