Henz Tampon inserted, Auto Acquired, next purchase a new handbag Donating Members 9,946 Member For: 16y 10m 17d Gender: Male Location: Vic Posted 30/01/11 03:53 AM Share Posted 30/01/11 03:53 AM I think the tray sitting low with tubs would look mad if the fronts low enough too. You'll have to sort out the ride height so it sits level. Link to comment Share on other sites More sharing options...
STAINLESS again plz You've changed man.... Donating Members 8,142 Member For: 14y 1m 10d Gender: Male Location: 2 Fuchsia Court, Narre Warren. 3805 Posted 30/01/11 09:27 AM Author Share Posted 30/01/11 09:27 AM the front ride height is spot on now... not planning on changing it... there will be a string line when time to sit tray on and get brackets in position so tray sits dead level...The rubber will sit 25mm into the tray at the back. Tomorrow Im notching out the RHS and capping it all in so it gives about 80mm clearance for up and down travel. Link to comment Share on other sites More sharing options...
STAINLESS again plz You've changed man.... Donating Members 8,142 Member For: 14y 1m 10d Gender: Male Location: 2 Fuchsia Court, Narre Warren. 3805 Posted 30/01/11 10:16 AM Author Share Posted 30/01/11 10:16 AM Link to comment Share on other sites More sharing options...
Dagabond Bored Member Administrator 35,722 Member For: 22y 2m 23d Gender: Male Location: Dé·jà vu Posted 01/02/11 01:38 AM Share Posted 01/02/11 01:38 AM http://www.duratray.net.au/index.php?link=steel-ute-trays Link to comment Share on other sites More sharing options...
Rootster Just a large member member Silver Donating Members 3,125 Member For: 16y 3m 21d Gender: Male Location: sydney Posted 01/02/11 05:01 AM Share Posted 01/02/11 05:01 AM looks so much better in octane....you might as well change the colour while your at it........ Link to comment Share on other sites More sharing options...
Dillz Three pedals are better then two.. Donating Members 15,637 Member For: 17y 8m 11d Gender: Male Location: Melbourne Posted 01/02/11 05:09 AM Share Posted 01/02/11 05:09 AM Hey Ben does this tray have to be practical or just look tuff as nails? Cause if just for looks have you considered like the Octane one but with the lower part still in place. For lack of a better description like a standard ute but with the tub part from the try up taken out if that makes sense?? Link to comment Share on other sites More sharing options...
STAINLESS again plz You've changed man.... Donating Members 8,142 Member For: 14y 1m 10d Gender: Male Location: 2 Fuchsia Court, Narre Warren. 3805 Posted 01/02/11 05:26 AM Author Share Posted 01/02/11 05:26 AM http://www.duratray.net.au/index.php?link=steel-ute-traysThey look ok, but the attention to detail is not there. Im not a fan of the much smaller 50x25 rhs round the outside. My bars will continue under the tray to form a step. The cassis will be clad off in stainless steel from the wheels back forming a drop tank look. The exhaust tips will be poking out of it somewhere either the back or the side/s. My mufflers and pipes are all hidden away neatly. Ill be using led strip tail lights mounted onto the stainless cladding underneath. Im not a fan of how much space there is between the wheel and the tray, needs to be much lower. The section at the front protecting the cabin looks like an afterthought. Im sticking with the checkerplate and maybe sprayed same colour as cabin. They do look good but the one im building, every part of it will be a feature. Not to mention a good advertisement for my business. And I bet I do it for half what they charge Link to comment Share on other sites More sharing options...
xtremerus Member 59 Member For: 15y 9m 14d Location: North-West NSW Posted 01/02/11 06:02 AM Share Posted 01/02/11 06:02 AM Hi all..Im going to build a tray for my new fg XR6T and am wondering if the mounting points are the same for an fg as they are for a ba/bf.I ask because a friend has an alloy tray in his garage off a ba and I want tobuild mine and just take the mounting positions from it.Does anyone know if I will run into any problems doing this?Cheers...-BenAll the same chassis. My tray has gone from AU>BF11>FG Link to comment Share on other sites More sharing options...
STAINLESS again plz You've changed man.... Donating Members 8,142 Member For: 14y 1m 10d Gender: Male Location: 2 Fuchsia Court, Narre Warren. 3805 Posted 02/02/11 08:13 AM Author Share Posted 02/02/11 08:13 AM Hey Ben does this tray have to be practical or just look tuff as nails? Cause if just for looks have you considered like the Octane one but with the lower part still in place. For lack of a better description like a standard ute but with the tub part from the try up taken out if that makes sense??Think I know what you mean. Just looks like the tub been cut of horizontally and a floor put on... I seen one and its not for me. Link to comment Share on other sites More sharing options...
Kv! Donating Members 1,132 Member For: 14y 11m 21d Gender: Male Location: Eastern Suburbs, Melbourne Posted 03/02/11 09:04 AM Share Posted 03/02/11 09:04 AM Is this done yet? Link to comment Share on other sites More sharing options...
