  • Turboless
  • Member For: 14y 2m 13d
Ah k, forget all my post then :P Hahahah. It just come to my mind when thinking about how it could be mounted. Other choice onto the chassis? Somehow? Lol
  • Member For: 14y 9m 13d
  On 06/04/2012 at 12:48 AM, ozking1 said:
Yer theyre hung up by a cable, pain in the arse when youve got a flat when its lowered
bad, I can barely slide it out when my car is jacked up
  • You've changed man....
  • Member For: 14y 4m 13d
Theres so a "fixed" there but ill leave it alone haha.
You dont count jd coz your cars practically submerged in the hwy.
broken
fixed
and yes or no??
Edited by STAINOnegger
  • Member For: 15y 3m 22d
That far back on the exhaust usually needs a bit of movement. On yours thou that would probably result in noises from the muffler hitting the tray or chassis.
Other option is to put a flex piece of exhaust in to stop the transmission of movement through the whole system.
  • Member For: 15y 6m 14d
I'd be looking to put a fair bit more flex in that mount.
there is atleast 20mm of sideways movement in the rear muffler with the nolothane bushes in place, the brocken bracket was from the sheer weight of the muffler bouncing up and down and the bracket design with one weld across the 0.9mm sheet used on the muffler.
was enevitable it was going to tear it open like a tin can.
However I am picking up 600mm of flex pipe tomorrow arvo and replacing about 400mm where it goes over the diff and maybe a piece about 200mm just before the mount I made to the gearbox, but Im not sure on that one yet.
Once that's done the rear muffler will be solid mounted to get rid of the annoying rattles Im still getting from the mounts.
