iotlek Member 17 Member For: 17y 6m 3d Gender: Male Location: Perth Posted 21/01/11 11:29 AM Author Share Posted 21/01/11 11:29 AM Hi GuysRight I am trying to remove my turbo to investigate/inspect it for issues I have been havingI have read the thread "removal-of-turbo-in-preperation-of-porting-and-valve-mod" Basically I have been at this for 3 nights (2-3hrs each night) to try and get the 2 right hand side bolts for the Turbo to manifold stud/nuts undone. I do not know what to do as for the life of me I can not get them undone.I have tried every spanner I have, including ratchet as mentioned in the thread, also unbolted the actuator bracket to help.(photo stolen from removal-of-turbo thread)I have tried every angle I can think of to get it off I have used wd40 etc...The problem is these 2x nuts appears to be warn plus the lining up of the nut is either to far each way (if the spanner is hitting each side of the turbo before it even grips if you know what I mean)I am not sure what to do now and how I am going to get these 2x nuts off.Can I use some sort of lock wrench like this at least for the top one. And maybe something else for the bottom one ?What can I do.Cheersio Link to comment Share on other sites More sharing options...
SuckSqueezeBangBlow ʎǝʞuoɯ ɹoıuǝs Donating Members 1,808 Member For: 16y 8d Gender: Male Posted 21/01/11 12:38 PM Share Posted 21/01/11 12:38 PM maybe remove manifold and turbo together so you can work with it on a bench? Link to comment Share on other sites More sharing options...
iotlek Member 17 Member For: 17y 6m 3d Gender: Male Location: Perth Posted 21/01/11 01:40 PM Author Share Posted 21/01/11 01:40 PM (edited) I was thinking about this but was hopping there might be another solution before having to do this. Also I am not sure its going to help me that much with the crapped out top bolt (bottom one seems to be in good condition its more of a access issue with that one.In the case I do have to go this far I assume I would need to get a new gasket for the manifold when I bolt it back up or can I reuse the existing one ?Cheers Edited 22/01/11 02:05 AM by RHR No need to quote above post. USE FAST REPLY Link to comment Share on other sites More sharing options...
Bonjaz Donating Members 1,841 Member For: 16y 16d Gender: Male Location: CQ Posted 21/01/11 02:43 PM Share Posted 21/01/11 02:43 PM take it all off and do it on the bench...we snapped the bottom rhs one on my mates not a fun job drilling and retapping hole but much much easier when its all off the car Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 19y 3m 1d Gender: Male Location: Perth Posted 21/01/11 02:53 PM Share Posted 21/01/11 02:53 PM Put it all back together, run the car till its hot and the try while its all still warm.Otherwise some careful application of heat and delicate use of a chisel will get the nut moving Link to comment Share on other sites More sharing options...
Wenier Donating Members 1,736 Member For: 14y 11m 6d Gender: Male Location: Christchurch, New Zealand Posted 21/01/11 09:09 PM Share Posted 21/01/11 09:09 PM Dont use the grip pliers as you'll just ruin the nut more. Another option along with having it warm which may loosen it is to get a spanner and trim the sides of the ring down to make it fit.The spanner will end up pretty weak but you might just get it and enough access with it shaved/trimed down. Link to comment Share on other sites More sharing options...
Benny Member 1,869 Member For: 21y 4m 18d Gender: Male Location: Newcastle Posted 21/01/11 09:20 PM Share Posted 21/01/11 09:20 PM Have you tried bending the handle on the spanner to make it slide between the turbo and manifold rather than hit the housing? Or even have a look at a ratchet spanner with fine tooth gearing.Benny Link to comment Share on other sites More sharing options...
spoolxr6 Member 312 Member For: 14y 1m 9d Posted 21/01/11 10:22 PM Share Posted 21/01/11 10:22 PM On the top right nut all you need is the ring end of the spanner on there to crack it. The bottom right needs a nuckle end extension with a socket on it and you get it from under the turbo with a ratchet. Link to comment Share on other sites More sharing options...
ZAP No boost, no bottle, just my foot on the throttle! Lifetime Members 7,935 Member For: 20y 10m 10d Gender: Male Location: Sydney Posted 21/01/11 11:40 PM Share Posted 21/01/11 11:40 PM Remove the manifold and do it on the bench.This is the only way to do it now or you will only cause more damage and end up removing the manifold anyway. Link to comment Share on other sites More sharing options...
spoolxr6 Member 312 Member For: 14y 1m 9d Posted 21/01/11 11:52 PM Share Posted 21/01/11 11:52 PM If you have a bracket going to the engine mount on the bottom it is hard to remove the manifold without un doing the bottom right nut at least. Link to comment Share on other sites More sharing options...
