  • My new toy
  • Member For: 22y 1m 22d
I feel sorry for you mate this is not good at all.
As for bent rod they will knock before the bearing stuffs up as it tries to turn the piston over in the bore and also hits the side of the bore.
I would be on there door step tomorrow demanding they fix your motor and tune it right or tell them you are going to consumer affairs about it.and than aca or today tonight.
Ian
  • Replies 109
  • miso xr6
  • Member For: 16y 6m 4d
Thanks mate, anyways I have just finished doing a comp test on it an it seems that cylinder 3 was lower on comp then the other cylinders,cylinder 3 read at 188 psi,while the rest of the cylinders were at 205psi,I noticed that cylinder 3 was inline with my crossmember exactly were I noticed the most knocking noise.
Hey guys,it looks like its time for me to put the car back in the garage and put a cover on her, motor is knocking louder and louder every time I drive it. Now I know the bottom end is rooted, what would you reckon the best thing for me to do, should I go and buy a fg f6 bottom end, I got quoted 2700 dollars for it. I will install it myself to safe some cash that's one option, or should I do a rebuild on my current motor, install spool rods, cp pistons, and all the other parts needed for the rebuild. Now one thing im not sure of is how much the build motor will set me back, has any one done something similar how much did it cost in parts?
thanks for all your replys guys an I really appreciate your input on this topic
thanks
mic
  • A much better forum
  • Member For: 16y 10m 21d
Built motor will cost anything from $5k in parts up to $14k...
Depends on how much power you want? If it's a 4 speed... Just go the FG F6 bottom end... You'll have to do a bit of modification to the sump I think... But the bottom end will hold more power than the 4 speed ever will (with a decent tune that is!)
  • Just a large member member
  • Member For: 16y 7m 28d
that's just farked cccc...We buy and play with our cars to enjoy them....I feel for you and know this must be hard to accept...
You thought you would save some money ...but in returns you were bum farked without vaso...........
Maybe they have been busy rebuilding the twin turbo mustang...
As that looks like its had more engine rebuilds than passes........
Mate what can I say..other than that's just farked.............Hope you enjoy christmas and its doesn't damper your break to much..........
Whats done is done...you can't change that............
Just keep this thread going to save other people the grief they caused you...........
What a bunch of farken :censored: ............Its easy to bad mouth others to make yourselves look good.....
Have a good look outside the box boys..................
In todays std your not even playing junior league.............
How about a $300 :pooh: tune next christmas..might save some an extra $100 when they need to rebuild it.............
  • miso xr6
Well I guess the fg f6 motor would be my best option, yea I thought that even if I rebuild the motor myself it would have been starting at the 5000 dollar mark, thanks Worm.
  • Member For: 15y 3m 28d
drop the car at the tuner, tell them what they have done to the car now, tell them that you will be back in a month to pick the car up when its all fixed, all covered by them of course.
This is bullsh*t, fair enough if it was a month or 2 after that the car started playing up, that could be a driver fault, but if you took your car in "modifying" condition, expecting decent power and a safe tune/car, drive out the door and the car is notably f*cked, that is not your fault.
You did the right thing by going back, giving them a few chances to fix the problems, which only seemed to get worse. That is BS, seriously dump the car there, make the pricks fix it, properly this time, threaten to take further action if they don't comply
It's like dropping your newborn in for heart surgery and the *beep* doctors f*ck it up... Through negligence... Not a lack of time or resources...
What do you do? You sue!!!
  • Banned
  • Member For: 15y 10m 27d
Well seems a few people now are popping and looking for upgrades. Ive put this offer to a few threads over past few days. I have an 07 ~25,000km's all up f6 tornado motor ill put for sale soon. will be bout 3500-4000 (no turbo). pm me if your interested.
  • miso xr6
It is bullsh*t what happened man an im for sure gonna take action.
Guest
This topic is now closed to further replies.
