Worm A much better forum Silver Donating Members 3,808 Member For: 16y 9m 11d Gender: Male Location: Victoria Posted 22/12/10 10:04 AM Share Posted 22/12/10 10:04 AM Maybe *Beep* should bring his to you Danny? Link to comment https://www.fordxr6turbo.com/forum/topic/72260-the-btr-4-speed-auto-thread/page/4/#findComment-1065834 Share on other sites More sharing options...
BOZZTURBO Donating Members 237 Member For: 18y 9m 5d Gender: Male Location: Melbourne Posted 22/12/10 11:58 AM Share Posted 22/12/10 11:58 AM worm , Link to comment https://www.fordxr6turbo.com/forum/topic/72260-the-btr-4-speed-auto-thread/page/4/#findComment-1065881 Share on other sites More sharing options...
RIP_HSV HOON Member 1,636 Member For: 15y 1m 19d Gender: Male Location: W.A Posted 22/12/10 12:35 PM Share Posted 22/12/10 12:35 PM On 22/12/2010 at 1:34 AM, bjcrown said: So it seems an external tranny cooler is the way to go.I dare say it is to bypass the stock one. Can someone please advise the size required (for say a tuned 245rwkw car)?Thanks,Check out B&M cooler kits Link to comment https://www.fordxr6turbo.com/forum/topic/72260-the-btr-4-speed-auto-thread/page/4/#findComment-1065891 Share on other sites More sharing options...
RIP_HSV HOON Member 1,636 Member For: 15y 1m 19d Gender: Male Location: W.A Posted 22/12/10 12:37 PM Share Posted 22/12/10 12:37 PM On 22/12/2010 at 1:20 AM, Headsex said: Why waste your money on those electronic shift kits when you can do the same via the tune in these cars.People do vary the clutches they fit, but realistically the factory ones is all mine has. its good enough. Cryogenic the parts do help, but you can still break the plantery's.Billet servo necessarily required, but helps with bigger power, but is known to break the band. Where some shops even weld the band to increase its strength.good for those who want to keep the car stock...... Link to comment https://www.fordxr6turbo.com/forum/topic/72260-the-btr-4-speed-auto-thread/page/4/#findComment-1065893 Share on other sites More sharing options...
YOB POM Member 140 Member For: 19y 10m 29d Gender: Male Location: Jimboomba Qld Posted 22/12/10 03:17 PM Share Posted 22/12/10 03:17 PM On 22/12/2010 at 8:57 AM, turbotrana said: The S3, S4 and S5 solenoids are all there to provide soft shifting for the girls. By shutting off the S3 and S4 you render the S5 redundant and it maintains full line pressure to the bands and clutchs. Fluids are going directly to the bands and cluches instead of bypassing through these solenoids which gives extremely firm shifting.You dont need to modify the box internals, you dont need to drop the pan, you just need to disconnect the solenoids and trick the ECU into thinking the solenoids are still there by putting a couple of resistors to ground. It is so simple and cheap and works great.Yet people are still talking about external oil coolers to save their box, different oils, electronic shift kits which are nothing compared to this mod. Its all about getting the box to shift hard and fast under load which makes it survive more than anything else. Yet I find this mod so overlooked but the guys who do try it find its a great bang for you buck mod. Its similar to what Headsex said above"" I've seen modifications to remove the bias feed to the back of these circuits, which as a PRO allows maximum pressure, however with a CON of Maximum pressure 100% of the time, and NO PCM controllability.Not recommended, however a lot of auto shops do this.""Whilst I am no pro box builder, I personally do not want any PCM controllability on the BTR for performance purposes as IMO its the soft shifting circuits in this box that stuff it up in the first place so just get rid of them.Hows this done?John. Link to comment https://www.fordxr6turbo.com/forum/topic/72260-the-btr-4-speed-auto-thread/page/4/#findComment-1065913 Share on other sites More sharing options...
XR64LT Donating Members 678 Member For: 17y 3m 26d Gender: Male Location: sydney Posted 22/12/10 11:03 PM Share Posted 22/12/10 11:03 PM YOB POM, just in your sig I didnt think blue print came out in 04 models, isnt that shockwave. could be wrong though. Link to comment https://www.fordxr6turbo.com/forum/topic/72260-the-btr-4-speed-auto-thread/page/4/#findComment-1065961 Share on other sites More sharing options...
Worm A much better forum Silver Donating Members 3,808 Member For: 16y 9m 11d Gender: Male Location: Victoria Posted 22/12/10 11:35 PM Share Posted 22/12/10 11:35 PM Definitely did... Shockwave came out on series 2... Link to comment https://www.fordxr6turbo.com/forum/topic/72260-the-btr-4-speed-auto-thread/page/4/#findComment-1065983 Share on other sites More sharing options...
turbotrana Member 2,586 Member For: 22y 1m 4d Gender: Male Posted 23/12/10 01:06 AM Share Posted 23/12/10 01:06 AM I posted this mod on this forum November 2004. See thread. Link to comment https://www.fordxr6turbo.com/forum/topic/72260-the-btr-4-speed-auto-thread/page/4/#findComment-1066022 Share on other sites More sharing options...
r32dan Donating Members 62 Member For: 14y 5m 6d Gender: Male Location: Gold Coast Posted 26/12/10 06:34 PM Share Posted 26/12/10 06:34 PM hey guys, read the above link, and although it is a very clever little trick (as resistor mods always are) I would rather spend the $70 or so to buy the actual shift kit that retains your engine braking, and allows you to adjust the firmness of the shift....but......is there any point in doing so if I plan on flash tuning the car....I hear that the flash unit also firms up changes as well, or would it not really compare with the results I would get from the dedicated shift kit? oh yeah, and also, would they be compatible together? Link to comment https://www.fordxr6turbo.com/forum/topic/72260-the-btr-4-speed-auto-thread/page/4/#findComment-1066894 Share on other sites More sharing options...
tquarrell Member 181 Member For: 20y 9m 1d Gender: Male Location: Sydney, NSW Posted 26/12/10 07:59 PM Share Posted 26/12/10 07:59 PM Quote It appears that the planetary gears are the week point.Does anyone know the model number of the 4 speed auto used in the xr6 turbo's? The reason I ask is that when the xr8 (500nm) and gt (520nm) were introduced there was a 6 month wait because btr & fpv designed a whole new box (internally) called the m97-019 because the box used in the xr6 turbo (450nm) and 5.4 3v (470nm) wasn't strong enough. Quote FPV worked closely with local automatic transmission manufacturer BTR to deliver a premium performance automatic transmission (optional on all models) that meets a wide range of tough local demands, including high ambient temperatures and heavy towing. Quote As a result of close liaison between BTR and FPV, the new M97-019 auto is a transmission engineered to match the characteristics of the Boss engine. Quote After an intensive development period and extended durability testing, FPV’s new automatic transmission has a special high torque gear set and torque converter unique to the Boss engine. http://www.performanceforums.com/forums/archive/index.php/t-67140946.htmlSo I guess my real question is are the FPV/xr8 auto's any stronger than the ones used in the xr6 turbo, and can they be/has anyone fitted one to an xr6 turbo? Link to comment https://www.fordxr6turbo.com/forum/topic/72260-the-btr-4-speed-auto-thread/page/4/#findComment-1066900 Share on other sites More sharing options...
