  • HOON
  • Member For: 15y 1m 18d
  On 21/12/2010 at 1:11 AM, r32dan said:
can these boxes be shift kitted, stronger bands ? I was told there isnt much out there for them, unlike the old Expensive Daewoo 4 speed where there is heaps of aftermarket gear for them...does this sound correct.....
you can buy electronic shift kits for them there are 3 stages from Shiftkits.com.au
there's not alot you can do to them,bigger aftermarket transcooler, fit au pump, clutches, cryogenic the hard parts, billet servo
Edited by RIP_HSV
  • Member For: 17y 10m 7d
well if 83000kms of daily driving with a 2800 convertor plus many runs down the dragstrip counts then hell yeh theyre reliable...
oh and also 2 yrs and not a problem with the trans, had it pulled out and inspected and was still like brand new.
If your exceeding over 400rwkw then I would say best find another trans for the long run.
What I dont do when driving is leaving it in D and sit on the convertor in 4th gear doing 60kms hr, your just creating unnecessary heat , and heat is one of the biggest killers of transmissions. I actually drive mine like a full manualised auto.
Service it twice a yr.
All that's done to it is au pump, planeteries, modified servo, and a couple of other small things.
  • Member For: 17y 11m 7d
By "full manualised auto" do you use sports mode or still change old school?
  • Member For: 14y 5m 5d
It appears that the planetary gears are the week point. Mine has a slight high pitched whine in first. There is some good info here especially the link above containing all the vids, BUT, alot of the examples given are from cars running big power. No one has answered the reliability question as to how much the "standard" box in reasonable condition, can withstand on say a mildly modified daily driver (aprox 250rwkw). If I was to run a trans cooler and do a yearly service can this box be reliable with sort of power?
I'm pretty sure it has but yeah going by the guys on here you should be right with that sort of power. Don't quote me on that though..
  • HOON
Have heard of tune only cars killing btr's if you dont want to break it leave it stock or just a tune I would say 250rwkw's would be as far as you should go after fitting a bigger cooler, from personal experience my stock btr went with 270ish rwkws (tune, injectors and exhaust system) about 12 times back to trans shop for repairs a mate of mine went to just over 300 rwkws and lasted at that for approx 2 months before buying a built box and that's lasted 6 months so far, the tune has alot to do with longevity of these boxes less low down torque and a more progressive torque curve seems to help!!
  • Member For: 22y 1m 2d
IMO the best way to increase the life of this box is to disconnect the S3 and S4 solenoids so that the box shifts hard. The so called shift kit by playing with the S5 solenoid is not the way to get everything shifting as hard as possible and doing it thru the tune isn't either. I have detailed this mod previously so not going to explain it in detail again. If you are really electronic literate you can get this mod to work just under load so that soft shifting during normal driving and hard under load.
