  • Member For: 17y 7m 15d
Im looking to fit a 12pnd actuator before babying the car to the tuners for a tune, but want to know if there is a trick to setting the actuator arm up, as it has an adjustable rod.
Is it a matter of matching the length with the old actuator and arm I take out for correct throw length, or can you only get a correct setup of this arm when its installed so you can feel the resistance on the diaphram?
  • Member For: 14y 7m 13d
The arm length should be exactly the same, the throw of the actuator isn't changing, its just changing the pressure at which it actuates, the internal gate will only move the same distance. If you change the length of the actuator rod it may not close the internal gate all the way or it may not open it all the way.
Hope this helps.
  • 570Nm @1800rpm
  • Member For: 21y 7m 11d
Get the old actuator out and then adjust the new one to be the exact same length. You will notice a massive difference in resting tension between stock and the 12lb actuator.
