DUS12 Member 471 Member For: 17y 11m 27d Posted 10/10/11 12:45 AM Share Posted 10/10/11 12:45 AM just hold it flat you pussy chad........all the suffering is worth it for the idle:)dave got mine ideling smooth as and I told him to change it back haha Link to comment https://www.fordxr6turbo.com/forum/topic/72171-ba-xr6t-ute/page/7/#findComment-1147801 Share on other sites More sharing options...
blow off Donating Members 199 Member For: 16y 10m 28d Gender: Male Location: Airlie Beach - FNQ Posted 28/10/11 12:05 PM Author Share Posted 28/10/11 12:05 PM Thanks for the support lads.. We have managed to get it running OK below 3000rpm on a 98 tune, but needs work and have run out of time. Dave has been great. Heading back over to the land of smiles on Tuesday for long time. Dave wacked 9 degrees into it and boosted to only 24psi and it made 470rwks before the Dyno packed it in.Leaving it with my mechanics to sort out the other issues and when return to our great land we will get straight back into tuning/running it down the strip, pending any failures... Cheers Gents and will keep current with what you mad F#ckers are doing with all these BOOSTED rigs. Link to comment https://www.fordxr6turbo.com/forum/topic/72171-ba-xr6t-ute/page/7/#findComment-1154469 Share on other sites More sharing options...
bjc Donating Members 2,823 Member For: 21y 9m 28d Gender: Male Location: Townsville Posted 28/10/11 02:33 PM Share Posted 28/10/11 02:33 PM 6. After putting the boot into it and then off throttle boost/power is held for 3-5 seconds and the Ute still powers up and along....maybe a bigger blowoff valve ???, this is only with around 24psi and up. Glad it hads 6 pot Brembos and 4's on the rear, LOL.Maybe fit dual blowoff valves also? Link to comment https://www.fordxr6turbo.com/forum/topic/72171-ba-xr6t-ute/page/7/#findComment-1154506 Share on other sites More sharing options...
blow off Donating Members 199 Member For: 16y 10m 28d Gender: Male Location: Airlie Beach - FNQ Posted 26/02/12 03:14 PM Author Share Posted 26/02/12 03:14 PM (edited) You lads are going nuts with this these XR6T's !!!!Really starting to miss the Ute (You Lads are having too much fun !!) due to still being in Thailand and what has been going on with it while over here....After the last round of tuning (Like 4 months ago) found once again some lose stuff around the waist gate, when thinking and feeling she was not just right. Found the problems and all sorted and rang Dave before taking off OS to make sure AFR's would be cool with extra boost, now felts like 540rwks on 24psi on pump and without the lag.Have been looking on with keen interest with fellow members on the head lifting problems regarding boost, got all the big head work, Studs, Cams and Copper gasket with the new 998R ATOMIC donk, what have you lads been boosting these to with these spec's. Did a sh*t load of looking into this regarding motor, turbo, box, stall and diff ratios. It will make what is does on the day but wanting to match the turbo to the motor and push 36+ PSI on Meth, that's my goal as a Dyno Bitch. Running it as a track Ute, well that's a different story. Got the sh*ts with the T400 problems and got Brinks In Townsville to build it good for 1500ph+ on 4000lb allowing big boost out of the 42 GTX Garrett. He changed the Trans brake set up too. Here is what's been done.Billet Steel rollerized fwd hub Griner 34G10 Billet Trans Brake Valve Body 300 maraging alloy Input shaft XL Aluminimum drum w/ 36 element sprag 5 disc Intermediate clutch stack Modified oiling & breather system 5 disc HP Waffle Red Direct stack Intermediate Case strutWe have done some other mods to keep temps down in the engine bay with stuff like keeping fuel temps down with running all 4 044 pumps via boost, meaning the more boost the more pumps kick in. Before with running 2 pumps all the time within 20 minutes the fuel was near 70 deg, on PUMP. Methanol will be a happier story. Dave wants to tune it running on 98 first and then get into the meth. Looking forward to getting the right set up and having fun with it. Want to get the Ute down to Dave while I'm still over in Thailand for the next 3 months for him to get it to its full output Edited 26/02/12 03:21 PM by blow off Link to comment https://www.fordxr6turbo.com/forum/topic/72171-ba-xr6t-ute/page/7/#findComment-1202081 Share on other sites More sharing options...
Bonjaz Donating Members 1,841 Member For: 16y 6m 24d Gender: Male Location: CQ Posted 26/02/12 09:18 PM Share Posted 26/02/12 09:18 PM good luck buddy it will all be worth it when its done...im off to see dave again on monday so he can give my new fg its first tune I have been without a boosted falcon for a few months and its killing me, so I cant imagine how your feeling Link to comment https://www.fordxr6turbo.com/forum/topic/72171-ba-xr6t-ute/page/7/#findComment-1202114 Share on other sites More sharing options...
tray_182005 Member 1,226 Member For: 15y 10m 25d Gender: Male Location: Wee Waa/NSW Posted 29/02/12 07:51 AM Share Posted 29/02/12 07:51 AM Cant wait 4 this to run at full tilt Link to comment https://www.fordxr6turbo.com/forum/topic/72171-ba-xr6t-ute/page/7/#findComment-1203829 Share on other sites More sharing options...
