01txr Member 861 Member For: 18y 4m 16d Gender: Male Location: QLD Posted 31/12/10 10:38 AM Share Posted 31/12/10 10:38 AM On 31/12/2010 at 7:47 AM, XR09 said: That rod looks like it had a hairline fissure/crack for a while before it let go completely. Well from the discoloration on one half. Poor little thing did it's best ha haAnd that's one big gerbil wheel Yes maybe start of a crack but it would not have been long before it broke.See how bad the casting is in the dark area, very porous.These are the issues of cast iron, no consistancy in grain flow or partical bonding.Just wish ford had went with a Forged rod and steel crank for the I6.Maybe they learned the hard way and want to now put the rod problem to rest.Its only a baby TO4z with .96 rear. was pretty good as it had beat other cars with large frame turbos.Very good power right over rev range, made boost from as low as 1100rpm and max set 12psi before 2400rpm.High eco of 8.8l to the 100k.Was very happy till that plastic rod spoilt the fun.People really need to take note why the Coyote is so much better.Cast iron is really only good for bbq plates or pot belly stoves.Have a Happy New Year guys and Gals, Im outa here Link to comment https://www.fordxr6turbo.com/forum/topic/72118-f6-310-vs-335-gt-raceway/page/14/#findComment-1068041 Share on other sites More sharing options...
bunna Donating Members 813 Member For: 18y 9m 5d Posted 01/01/11 01:11 AM Share Posted 01/01/11 01:11 AM You can't see the grain structure of the iron in those photos (you need a microscope). Link to comment https://www.fordxr6turbo.com/forum/topic/72118-f6-310-vs-335-gt-raceway/page/14/#findComment-1068110 Share on other sites More sharing options...
01txr Member 861 Member For: 18y 4m 16d Gender: Male Location: QLD Posted 01/01/11 04:07 AM Share Posted 01/01/11 04:07 AM Photo don't do much for it. But yes to see the grain a microscope is needed. What I mean is by the markings and way and direction of the breakGoes you can tell the inconsistent grain pattern.The break follows the weakest path. I'm shocking at wording things the right way. Link to comment https://www.fordxr6turbo.com/forum/topic/72118-f6-310-vs-335-gt-raceway/page/14/#findComment-1068146 Share on other sites More sharing options...
Guest XR09 Guests Posted 01/01/11 04:32 AM Share Posted 01/01/11 04:32 AM (edited) LOL I am hopeless at expressing myself too. But you can see what you mean. Even where I think the fail started. And I think we are looking at a classic grey cast ??? Or is it a mallable ???? Either Iether lots of room for error and fail ha ha. Could be a good new post for us wannabees.Where did this rod start to fail and why ????? More detail than just a Sh&t rod. Like there..... and vibtration started the fail. Heat got in and ate the graphite/silicone or whatever properties it had in it, till it had half it's initial strength. Edited 01/01/11 04:42 AM by XR09 Link to comment https://www.fordxr6turbo.com/forum/topic/72118-f6-310-vs-335-gt-raceway/page/14/#findComment-1068151 Share on other sites More sharing options...
01txr Member 861 Member For: 18y 4m 16d Gender: Male Location: QLD Posted 01/01/11 05:57 AM Share Posted 01/01/11 05:57 AM So many things could have been the reason, only way to know for sure would be to have itexamined by a Metallurgists, Just not worth it for a $30 part.The main thing is Cast Iron has to many inconsistancies opposed to Forged.At this point it is just a sh*t rod and most know it.Wonder if there is a clip on bullet proofing showing the strengths of different materials.What would you stand behind a 4mm plate of cast iron or 2mm plate of Plate Steel, I choose the later.Here is a You Tube link to Forging Process that may be helpful to somehttp://www.youtube.com/watch?v=PXVWiGqeltMIf Its Got To Be Tuff - Go Coyote Link to comment https://www.fordxr6turbo.com/forum/topic/72118-f6-310-vs-335-gt-raceway/page/14/#findComment-1068175 Share on other sites More sharing options...
jimmixr Donating Members 686 Member For: 14y 9m 11d Posted 01/01/11 06:59 AM Share Posted 01/01/11 06:59 AM Great vid!! Link to comment https://www.fordxr6turbo.com/forum/topic/72118-f6-310-vs-335-gt-raceway/page/14/#findComment-1068182 Share on other sites More sharing options...
Dagabond Bored Member Administrator 35,722 Member For: 22y 6m 16d Gender: Male Location: Dé·jà vu Posted 01/01/11 07:00 AM Share Posted 01/01/11 07:00 AM Same process is used to make a Forging and a Cast Iron piece...it is just the materials used that differ...and some of the process, but it is basically the same. Link to comment https://www.fordxr6turbo.com/forum/topic/72118-f6-310-vs-335-gt-raceway/page/14/#findComment-1068183 Share on other sites More sharing options...
Guest XR09 Guests Posted 01/01/11 07:46 AM Share Posted 01/01/11 07:46 AM (edited) The Brinell scale characterizes the indentation hardness of materials through the scale of penetration of an indenter, loaded on a material test-piece. It is one of several definitions of hardness in materials science.Proposed by Swedish engineer Johan August Brinell in 1900, it was the first widely used and standardised hardness test in engineering and metallurgy. The large size of indentation and possible damage to test-piece limits its usefulness.The typical test uses a 10 millimetres (0.39 in) diameter steel ball as an indenter with a 3,000 kgf (29 kN; 6,600 lbf) force. For softer materials, a smaller force is used; for harder materials, a tungsten carbide ball is substituted for the steel ball. The indentation is measured and hardness calculated as:where:P = applied force (kgf)D = diameter of indenter (mm)d = diameter of indentation (mm)The BHN can be converted into the ultimate tensile strength (UTS), although the relationship is dependent on the material, and therefore determined empirically. The relationship is based on Meyer's index (n) from Meyer's law. If Meyer's index is less than 2.2 then the ratio of UTS to BHN is 0.36. If Meyer's index is greater than 2.2, then the ratio increases.[1]BHN is designated by the most commonly used test standards (ASTM E10-08[2] and ISO 6506-1:2005[3]) as HBW (H from hardness, B from brinell and W from the material of the indenter, tungsten (wolfram) carbide). In former standards HB or HBS were used to refer to measurements made with steel indenters.HBW is calculated in both standards using the SI units aswhere:F = applied force (N)D = diameter of indenter (mm)d = diameter of indentation (mm) Edited 01/01/11 07:50 AM by XR09 Link to comment https://www.fordxr6turbo.com/forum/topic/72118-f6-310-vs-335-gt-raceway/page/14/#findComment-1068194 Share on other sites More sharing options...
QikSmurf Member 246 Member For: 21y 10m 18d Posted 01/01/11 07:50 AM Share Posted 01/01/11 07:50 AM On 30/12/2010 at 11:43 PM, cranny said: I Have a degree in Accounting and a Masters in Economics so I think we are going to have diffrent views on the way corporations operate.Oh how one sentence can reveal so much Link to comment https://www.fordxr6turbo.com/forum/topic/72118-f6-310-vs-335-gt-raceway/page/14/#findComment-1068195 Share on other sites More sharing options...
01txr Member 861 Member For: 18y 4m 16d Gender: Male Location: QLD Posted 01/01/11 09:34 AM Share Posted 01/01/11 09:34 AM XR09Think your talking in a different language there, but great work.Just these guys who think the I6 is better than the coyote even though so many have tried to point outhow much better the coyote engine is. They cant grasb the basics, they defeintly arn't going to understandwhat you have posted.I dont, but I have built engines since I was 15yo and you learn that cast is ok to a point, but forged is somuch better and that its a bit of cost differance.These days the cost differance isn't so huge.I started working as a VW Mech back in 88 and for instance a forged moly crank was over $5000 for a vw.a guy I knew back then from the workshop had a very quick street beetle running 11.7 NA and held the SSC bracketfor 3 years.No way a Cast crank would survive in that engine.The same guy went on to start up Crankshaft Engineering.I know as I was only a youngster on low pay and building engine after engine for my own street beetle.A hole engine would set me back a couple hundred so didn't matter if it broke, just ment I had to rebuild it.Could not afford a Steel crank.Dagabond what do you mean casting is similar?From what I know the only Similarities are that both get heated to molten metal both get poured into a mould.The cast goes into a mould that is at finished size except areas like bearing surfaces are larger so can be machined to size.from there it goes into cooling processes.It is as cast and not compressed.Forging goes into a mould suitable sized for the amount of material to be compressed into its desired shape.once it turns to a solid mass and still in a formable state it goes into the press mould where it is stamped into its desired shape.Once again the bearing surfaces are larger for final machining.There are other processes like magnetics and nitriting I have heard about but dont much about except it is toget the grain flowing in the right direction and to strengthen.Both Cast and Forging can be shot peened for added strength. Link to comment https://www.fordxr6turbo.com/forum/topic/72118-f6-310-vs-335-gt-raceway/page/14/#findComment-1068229 Share on other sites More sharing options...
