01txr Member 861 Member For: 18y 3m 11d Gender: Male Location: QLD Posted 09/12/10 12:10 PM Share Posted 09/12/10 12:10 PM Went into ford today to inquire about main girdle Windage tray for my new BA engine build. Anyway they list different part number for BA and fg turbo with the fg one being the cheaper option. What I would like to know is what the difference is and will they fit the BA engine. If they don't fit why and is it worth making it fit if practical. Are they thicker or stronger?I'm in need of one urgent as well sump. If anyone has one local to Brisbane let me know. Link to comment https://www.fordxr6turbo.com/forum/topic/72105-ba-to-fg-main-girdle-differences/ Share on other sites More sharing options...
spoolxr6 Member 312 Member For: 14y 5m 11d Posted 09/12/10 12:40 PM Share Posted 09/12/10 12:40 PM I think the FG sump has a lower clearance towards the rear of the sump and this is reflected in the design of the Windage tray when compared to the BA/BF. I'm sure someone with a bit more knowledge on the topic will tune in soon mate. Link to comment https://www.fordxr6turbo.com/forum/topic/72105-ba-to-fg-main-girdle-differences/#findComment-1062519 Share on other sites More sharing options...
bda12pleaseu Member 94 Member For: 17y 4m 6d Gender: Male Location: newcastle Posted 19/12/10 09:43 AM Share Posted 19/12/10 09:43 AM The sump in the Ba has no clearance for the baffle at no 6 cylinder so there is none there. As for the fg this isn't an issue so all cylinders have a baffle. I'm in the process of changing Ba to fg f6 bottom end hence how I know all u have to do is cut away the baffle part with tin snip its clear when you compare them what needs to be done . Also a point to make out here is nearly all fg parts are cheaper because ford want us to buy new cars instead of repairing old ones. I found this out when the price I received for a bf typhoon short motor was 300 dollers dearer and the fg is better any way.Hope this clears things up. Link to comment https://www.fordxr6turbo.com/forum/topic/72105-ba-to-fg-main-girdle-differences/#findComment-1064981 Share on other sites More sharing options...
bda12pleaseu Member 94 Member For: 17y 4m 6d Gender: Male Location: newcastle Posted 19/12/10 09:46 AM Share Posted 19/12/10 09:46 AM Also a hole needs to be added for the dipstick to go through it again u can see this when u compare them Link to comment https://www.fordxr6turbo.com/forum/topic/72105-ba-to-fg-main-girdle-differences/#findComment-1064988 Share on other sites More sharing options...
HI PSI Member 1,586 Member For: 18y 11m Gender: Male Location: Central Queensland Posted 19/12/10 10:08 AM Share Posted 19/12/10 10:08 AM (edited) Does a BA sump fit onto a FG F6 engine? Which girdle do I have to purchase? What modifications if any, are required? Edited 19/12/10 10:09 AM by HI PSI Link to comment https://www.fordxr6turbo.com/forum/topic/72105-ba-to-fg-main-girdle-differences/#findComment-1064994 Share on other sites More sharing options...
sexual harrassment panda I see a red door and I want to paint it black Donating Members 5,919 Member For: 15y 6m Gender: Male Location: Far north queensland Posted 19/12/10 11:25 AM Share Posted 19/12/10 11:25 AM yep BA sump and oil pickup will fit. I think FG F6 motors come with the girdle.Check out ebay - New fg f6 short and reco'd fg xr6t head with either a b series sump or fg sump for 5k Link to comment https://www.fordxr6turbo.com/forum/topic/72105-ba-to-fg-main-girdle-differences/#findComment-1065007 Share on other sites More sharing options...
01txr Member 861 Member For: 18y 3m 11d Gender: Male Location: QLD Posted 19/12/10 01:20 PM Author Share Posted 19/12/10 01:20 PM ThanksJust going to use a XT girdle. Will drill out spot welds to remove baffle plate splash shield piece for turbo oil return off my damaged girdle And tack it in place onto the XT one as it is the only difference. Or if I can scrounge enough doe I will get a atomic girdle. Link to comment https://www.fordxr6turbo.com/forum/topic/72105-ba-to-fg-main-girdle-differences/#findComment-1065022 Share on other sites More sharing options...
bda12pleaseu Member 94 Member For: 17y 4m 6d Gender: Male Location: newcastle Posted 20/12/10 06:44 AM Share Posted 20/12/10 06:44 AM Yes the sump fits but as well as above mods the dip stick hole ay the front is plugged just punch it out. Yes fg f6 short comes with girdle Link to comment https://www.fordxr6turbo.com/forum/topic/72105-ba-to-fg-main-girdle-differences/#findComment-1065145 Share on other sites More sharing options...
HI PSI Member 1,586 Member For: 18y 11m Gender: Male Location: Central Queensland Posted 20/12/10 10:35 AM Share Posted 20/12/10 10:35 AM Quote Yes fg f6 short comes with girdle Is there any gain in getting a Atomic girdle? What is the difference between the two? Link to comment https://www.fordxr6turbo.com/forum/topic/72105-ba-to-fg-main-girdle-differences/#findComment-1065201 Share on other sites More sharing options...
bda12pleaseu Member 94 Member For: 17y 4m 6d Gender: Male Location: newcastle Posted 21/12/10 05:38 AM Share Posted 21/12/10 05:38 AM (edited) To be honest I don't know and don't know there could be a pic on there web. I will check it out Edited 21/12/10 05:42 AM by bda12pleaseu Link to comment https://www.fordxr6turbo.com/forum/topic/72105-ba-to-fg-main-girdle-differences/#findComment-1065406 Share on other sites More sharing options...
