katrinaxr6turbo Inactive Members 1 Member For: 14y 4m 24d Posted 09/12/10 11:07 AM Share Posted 09/12/10 11:07 AM Hi, Can someone please help me. We have just put in a second hand ICC unit into my car as the old one was busted. When we have plugged it in, it comes up saying we need a code. I know this is generally specific to the car but does anyone know where I can find this info? Have looked through all the books and found nothing. Is it easier to take it to Ford and have them decode it? Thanks Link to comment https://www.fordxr6turbo.com/forum/topic/72104-decoding/ Share on other sites More sharing options...
Adam Here since the start... Lifetime Members 10,282 Member For: 22y 3d Gender: Male Location: Victoria Posted 09/12/10 11:16 AM Share Posted 09/12/10 11:16 AM You'll have to take it to Ford for that.I assume you swapped your original BEM onto the replacement ICC? Link to comment https://www.fordxr6turbo.com/forum/topic/72104-decoding/#findComment-1062496 Share on other sites More sharing options...
PSI40L Member 175 Member For: 22y 4m 12d Posted 04/01/11 03:59 PM Share Posted 04/01/11 03:59 PM Did you use your originally bem module. You have to recode it if not. Plus decode occur and graft your remotes again anyone with a decent scanner can do it Link to comment https://www.fordxr6turbo.com/forum/topic/72104-decoding/#findComment-1069123 Share on other sites More sharing options...
quadie Donating Members 720 Member For: 19y 5m 25d Gender: Male Location: Muswellbrook,NSW Posted 05/01/11 11:01 AM Share Posted 05/01/11 11:01 AM Below the ICC is the BEM(the 4 plugs that you undid )did you swap this unit or use the one with the Replacement ICCIf you didnt swap it , rmove ICC again and swap the BEM unitif you DID swap it did you RE-SEAT the ICC bus socket?you will find the instructions contained within my RCA mod (is a sticky)Also after replacing the ICC switch yor Ignition to on (but not start) for 10 secs then off again then on( the CAN bus wont talk to the ICC till the IGN is on.)hope that helpsif you cant swap your bem , your up for a trip to ford to the the BEM recoded Link to comment https://www.fordxr6turbo.com/forum/topic/72104-decoding/#findComment-1069328 Share on other sites More sharing options...
