2010G6E turbo New Member 9 Member For: 14y 7m 18d Gender: Male Location: Tom Price WA. Posted 06/12/10 11:57 AM Share Posted 06/12/10 11:57 AM hay all just wondering if any one has gone ane got a exhaust up grade on there g6e turbo. Heard if you go from turbo back you need a up graded feul pump and at least 80 pound injecters. Is this the go or is there a better way of going about it. All repleys would be great. Want the extra power and the note as well. Link to comment https://www.fordxr6turbo.com/forum/topic/72029-exhaust-upgrade/ Share on other sites More sharing options...
bjc Donating Members 2,823 Member For: 21y 9m 2d Gender: Male Location: Townsville Posted 06/12/10 02:33 PM Share Posted 06/12/10 02:33 PM If you want the better note just change the middle muffler as others on here have done. Your turbo wont handle much more than 330rwkw without changing to the F6 turbo so the exhaust at your point is a waste of money, but a cat change could be good or punch your out even.The search button is your friend here... Link to comment https://www.fordxr6turbo.com/forum/topic/72029-exhaust-upgrade/#findComment-1061385 Share on other sites More sharing options...
Benny Member 1,869 Member For: 21y 10m Gender: Male Location: Newcastle Posted 07/12/10 08:19 AM Share Posted 07/12/10 08:19 AM If you go turbo back you will need a custom tune due to the improved flow and to stop the car from going into limp mode. You don't need bigger injectors or a fuel pump to do this as the car can be safely tuned to the limit with exhaust only mods. You should be able to see around 270ish rwkw on standard injectors. If you want to go the next stage then injectors will be required. The fuel pump will be good for plenty more power. I'm still running my factory fuel pump.Benny Link to comment https://www.fordxr6turbo.com/forum/topic/72029-exhaust-upgrade/#findComment-1061617 Share on other sites More sharing options...
Ray076 Member 64 Member For: 16y 20d Gender: Male Location: NQLD Posted 09/12/10 05:41 AM Share Posted 09/12/10 05:41 AM Exhaust would be the last thing I would do. Just do the cat. I had standard exhaust and with all my xtras maxed the turbo at around 330rkw. I got full zorst system (xforce 3.5') and only gained a minumal xtra. Unless your thinking of changing the turbo at a later stage, spend money elsewhere as zorst doesnt need to be done. that's my 2 cents worth anyway. Link to comment https://www.fordxr6turbo.com/forum/topic/72029-exhaust-upgrade/#findComment-1062366 Share on other sites More sharing options...
tuono Member 312 Member For: 14y 6m 24d Posted 09/12/10 07:32 AM Share Posted 09/12/10 07:32 AM Cant argue with that. Experience is everything. Link to comment https://www.fordxr6turbo.com/forum/topic/72029-exhaust-upgrade/#findComment-1062401 Share on other sites More sharing options...
bossmang FREAKY Donating Members 12,440 Member For: 15y 5m 11d Gender: Male Location: Melbourne Posted 09/12/10 08:24 AM Share Posted 09/12/10 08:24 AM id go tune, and drop middle muffler. or tune and high flow cat. or tune, high flow cat and remove middle muffler if you still want some noise. Link to comment https://www.fordxr6turbo.com/forum/topic/72029-exhaust-upgrade/#findComment-1062424 Share on other sites More sharing options...
kink Member 294 Member For: 16y 10m 1d Gender: Male Location: Adelaide Posted 11/04/11 07:06 AM Share Posted 11/04/11 07:06 AM Just wondering how you went 2010G6E turbo. I am in the same boat at the moment, don't care for more power at the moment just want some noise, not overly loud. Do not like the odd sound made from dropping the centre muffler... Link to comment https://www.fordxr6turbo.com/forum/topic/72029-exhaust-upgrade/#findComment-1096191 Share on other sites More sharing options...
EWT New Member 12 Member For: 13y 8m 5d Gender: Male Posted 01/10/11 10:52 AM Share Posted 01/10/11 10:52 AM Would droping the rear muffler be the easiest , cheapest way to get an improved sound?Has anyone done this, and if so, any problems? Link to comment https://www.fordxr6turbo.com/forum/topic/72029-exhaust-upgrade/#findComment-1145562 Share on other sites More sharing options...
kink Member 294 Member For: 16y 10m 1d Gender: Male Location: Adelaide Posted 01/10/11 10:58 PM Share Posted 01/10/11 10:58 PM Yes I have, I wrote a huge write up in the exhaust section (removed centre muffler). Go have a look in there, tonnes of info... Link to comment https://www.fordxr6turbo.com/forum/topic/72029-exhaust-upgrade/#findComment-1145627 Share on other sites More sharing options...
MexicanBatman G666E Turbo!!! Member 1,008 Member For: 15y 4m 20d Gender: Male Posted 02/10/11 03:03 AM Share Posted 02/10/11 03:03 AM I've heard a tuned FG XRt with no rear muffler just a 3" pipe and it sounded greatI don't know if the dude is in here but YouTube search for Tims FG XR6 Link to comment https://www.fordxr6turbo.com/forum/topic/72029-exhaust-upgrade/#findComment-1145677 Share on other sites More sharing options...
