BCR01 Member 152 Member For: 14y 10m 1d Posted 01/12/10 02:41 PM Share Posted 01/12/10 02:41 PM When I give it to it, the syncro grinds from 1st to 2nd gear, seems to happen more when car is cold. has anyone had ths problem? Link to comment https://www.fordxr6turbo.com/forum/topic/71944-syncro-grinding-1st-to-2nd-under-hard-aceleraton/ Share on other sites More sharing options...
bjc Donating Members 2,823 Member For: 21y 9m 14d Gender: Male Location: Townsville Posted 02/12/10 12:24 AM Share Posted 02/12/10 12:24 AM I'll ask the Nephew as he has the same ute with a manual also up here in Ingham. I know when its warm it doesn't Link to comment https://www.fordxr6turbo.com/forum/topic/71944-syncro-grinding-1st-to-2nd-under-hard-aceleraton/#findComment-1060164 Share on other sites More sharing options...
QikSmurf Member 246 Member For: 21y 11m 5d Posted 02/12/10 11:06 AM Share Posted 02/12/10 11:06 AM Hi mate,Yes the shift between 1st and 2nd is notchy when cold. The first few shifts each morning I take deliberately slow - sometimes even double clutching! You will find that once the car warms up everything will be fine. If not then you have a problem.When I had my BA F6 with T56 gearbox it was very much the same. I had Mainlube gearbox oil put in and a lot of the bearing rollover sound disappeared and the gear changes were much smoother. I haven't bothered with the FG so far. It really is amazing that manufacturers use the sh*tiest oil possible when they build a car (Ford?). Link to comment https://www.fordxr6turbo.com/forum/topic/71944-syncro-grinding-1st-to-2nd-under-hard-aceleraton/#findComment-1060340 Share on other sites More sharing options...
