Guess My Power!
baoost
  • Member For: 14y 4m 26d
so what WOULD be realistic for my engine with the standard rods??? cause ill be getting the valve springs and gearbox change/mods. I swear ive read hundreds of threads with people having over 300rwkw on standard engines with upgraded valve spring?? why would mine be unrealistic.
are you thinking more like 310 - 320 would be realistic or like 280???
  • Replies 36
  • Member For: 16y 11m 19d
Between 330-350 would be right through a manual. You have all the supporting mods to keep it safe.
That's with a t56 not your 5 speed.
  • Member For: 15y 6m
I think you are being very unrealistic at that rwkw your rods will probably fail. If your tuner is fool enough to put that much power thru your current configuration , I guarantee it wont leave the dyno without at least either engine or gearbox failure.
I have one out there making those numbers on a stock BA 5 spd, the engine has been OK but gearboxes and clutches not so good. The gearbox failures tend to occur on the road not the dyno as on the dyno we are not going through gears under load and we can use the strongest gear, 4th, for tuning, you will likely break 2nd or 3rd.
The issue is at that power the tuning takes time and care, any amount of knock and you may have a big issue. I have seen FG XR6 springs float at 15 psi, for interest sake PAC valvesprings have about 10 pounds more seat and open pressure than FG XR6. Go for efficiency not boost. A good intercooler will allow more timing and more power at lower boost levels, more timing means cooler EGT's, better for the life of the turbo.
Edited by kartman
  • Dropping a turd
  • Member For: 17y 4m 12d
If you do, do the box and clutch then Id stay around 300. But with the money your thinking of spending you should consider selling your car an upgrading to an late 06 BF turbo or F6 and then start modding. There is a guy "slash " on the forum who did exactly what you are contemplating doing. Maybe PM him and he will explain the pitfalls. But in the end its your car and you can do what you want. I think maybe "Adrian6T" may have started with a ba 5 speed as well maybe PM him.
Edited by arronm
  • Dropping a turd
oil pump gears fail on manuals over 340rwkw ALOT which == engine rebuild. Be warey of that too.
True, I changed mine when I had 300. Billet gears and nizpro modified hosing and pressure relief.
  • Member For: 17y 9m 13d
I'd say about 3rd gear on 1st power run before gearbox explodes, (hope not but) start budgeting for a T56 :spoton:
