Jonno Member 79 Member For: 18y 8m 23d Posted 16/11/10 08:41 AM Share Posted 16/11/10 08:41 AM As I mentioned in the post below, the bolt connecting the gas strut to the body of my 2006 XR6T has rusted. I took to it with the spanners and it came loose - but cannot be retightened. I can just get my hand behind the bolt (behind the boot trim there are some access points) and it feels like there is a bolt or square piece of metal, but I have no way of clamping it (due to limited access) to see if it can be tightened.I went to the panel beater today and he said the only way to fix it was to drill a hole below the bolt to gain proper access, and then MIG weld it to the body. This seems expensive, and messy (the area will need to be repainted).Does anyone know an easy way to remove the old bolt and replace it with a new one. Or (sob) is the panel beater right?Thanks for your help.Jonno Link to comment https://www.fordxr6turbo.com/forum/topic/71681-help-replacing-gas-strut-bolt-in-boot-of-xr6t/ Share on other sites More sharing options...
Jonno Member 79 Member For: 18y 8m 23d Posted 18/11/10 07:29 AM Author Share Posted 18/11/10 07:29 AM Bump.If no one knows the answer - can anyone suggest where I can find out? I am in the inner west of Sydney.Thanks.Jonno. Link to comment https://www.fordxr6turbo.com/forum/topic/71681-help-replacing-gas-strut-bolt-in-boot-of-xr6t/#findComment-1056895 Share on other sites More sharing options...
hawlass Silver Donating Members 1,161 Member For: 17y 5m 22d Gender: Male Location: left right out Posted 18/11/10 08:48 AM Share Posted 18/11/10 08:48 AM Can you pull the bolt out far enough to get 2 or 3 mm of room between the back of the bolt and the body?If so, I'd have a go with a dremel and a cut off wheel ( these are only about 1mm thick). Make sure to cover the surrounding paintwork with some gaffa tape in case of a slip, and a few old sheets around the general area to protect from iron filings rusting later on and marking your paintwork.Once out I assume you can get at the back to fit a new nut on the new bolt?Good luck, and make sure to write up a how to thread once you finish, as I think you wont be the last with this problem. Link to comment https://www.fordxr6turbo.com/forum/topic/71681-help-replacing-gas-strut-bolt-in-boot-of-xr6t/#findComment-1056910 Share on other sites More sharing options...
Jonno Member 79 Member For: 18y 8m 23d Posted 19/11/10 05:26 AM Author Share Posted 19/11/10 05:26 AM There is no way to get to the back of the bolt.Jonno Link to comment https://www.fordxr6turbo.com/forum/topic/71681-help-replacing-gas-strut-bolt-in-boot-of-xr6t/#findComment-1057048 Share on other sites More sharing options...
hawlass Silver Donating Members 1,161 Member For: 17y 5m 22d Gender: Male Location: left right out Posted 19/11/10 06:11 AM Share Posted 19/11/10 06:11 AM I meant between the part of the bolt the strut attaches to and the body,the side you can see, not the back(inside) Link to comment https://www.fordxr6turbo.com/forum/topic/71681-help-replacing-gas-strut-bolt-in-boot-of-xr6t/#findComment-1057059 Share on other sites More sharing options...
Jonno Member 79 Member For: 18y 8m 23d Posted 06/12/10 12:20 PM Author Share Posted 06/12/10 12:20 PM I just had a quote of $600 to replace the bolt. Surely there must be a better way???????????Jonno Link to comment https://www.fordxr6turbo.com/forum/topic/71681-help-replacing-gas-strut-bolt-in-boot-of-xr6t/#findComment-1061364 Share on other sites More sharing options...
bjc Donating Members 2,823 Member For: 21y 7m 27d Gender: Male Location: Townsville Posted 06/12/10 02:22 PM Share Posted 06/12/10 02:22 PM Let me have a look tomorrow for you mate but surely there is a way (probably cheaper than $600 also!)No guarantees but I'll look anyways.Otherwise I was just thinking you could use a cutting wheel to get so far then a grinding wheel and give it a good tap and it should fall inside the body. Replace with a new one that will need to be tack welded though to stay in place. But then theres the old bit stuck in the frame somewhere to deal with! Link to comment https://www.fordxr6turbo.com/forum/topic/71681-help-replacing-gas-strut-bolt-in-boot-of-xr6t/#findComment-1061384 Share on other sites More sharing options...
bjc Donating Members 2,823 Member For: 21y 7m 27d Gender: Male Location: Townsville Posted 11/12/10 11:26 PM Share Posted 11/12/10 11:26 PM Well remembered to take a look at this today and there is access via the boot. Took some photos which are a bit dodge but you should get the drift. The access is via the oval hole closest to the back seat and there is enough room (over 2in x 6in) for a small to medium pair of needle nose pliers.There is a thread on the nut but no edges for a spanner as its tacked to the body as can be seen in the photo so that's why I'd reccommend the vice grips and a spanner on the ball joint to undo.Hope this helps even if a little late!Brett Link to comment https://www.fordxr6turbo.com/forum/topic/71681-help-replacing-gas-strut-bolt-in-boot-of-xr6t/#findComment-1062999 Share on other sites More sharing options...
