Xr6T Valve Springs, Fuel Pump And Injectors
  • 570Nm @1800rpm
  • Member For: 21y 4m 23d
Valve springs take about 4 hours from start to finish and injectors add about 30min to this as they can be done at the same time. Fitting a fuel pump to a sedan would take about 1 hour at the most.
Be careful when buying your fuel pump and make sure you get a genuine Walbro pump. If I was you I would talk to your tuner about sourcing parts etc, but you might be better off supplying them depending on what the tuner will charge.
With a BA Siemens Deka 60lb injects are more then enough and they are very commonly used, you can get a new flow matched set of 6 for about $350.
