XtRmn8 570Nm @1800rpm Donating Members 2,441 Member For: 21y 4m 24d Gender: Male Location: Perth, WA Posted 16/11/10 10:19 AM Share Posted 16/11/10 10:19 AM Valve springs take about 4 hours from start to finish and injectors add about 30min to this as they can be done at the same time. Fitting a fuel pump to a sedan would take about 1 hour at the most.Be careful when buying your fuel pump and make sure you get a genuine Walbro pump. If I was you I would talk to your tuner about sourcing parts etc, but you might be better off supplying them depending on what the tuner will charge.With a BA Siemens Deka 60lb injects are more then enough and they are very commonly used, you can get a new flow matched set of 6 for about $350. Link to comment Share on other sites More sharing options...
Sjorzie Member 27 Member For: 15y 2m 25d Posted 16/11/10 10:33 AM Author Share Posted 16/11/10 10:33 AM SENDER + WALBRO GSS340 FUEL PUMP FORD XR6 TURBO BAI would usually shop on ebay, but I found this fuel pump already installed in the sender for about 280 ? seems a pretty easy install then ?? Link to comment Share on other sites More sharing options...
XtRmn8 570Nm @1800rpm Donating Members 2,441 Member For: 21y 4m 24d Gender: Male Location: Perth, WA Posted 16/11/10 11:08 AM Share Posted 16/11/10 11:08 AM Yea that will be fine, that seller also has 60lb and 80lb siemens injectors. Link to comment Share on other sites More sharing options...
icer Banned 2,335 Member For: 15y 6m 28d Gender: Male Location: Aspendale, Vic. Posted 16/11/10 01:06 PM Share Posted 16/11/10 01:06 PM deka 60s are good for ~430rwkw + so they will be fine! Unless you want to go e85, then you want 1000cc. Link to comment Share on other sites More sharing options...
Sjorzie Member 27 Member For: 15y 2m 25d Posted 21/11/10 10:11 PM Author Share Posted 21/11/10 10:11 PM Thanks guys for all your info, been very helpfull,off to put in a fuel pump now Link to comment Share on other sites More sharing options...
Sjorzie Member 27 Member For: 15y 2m 25d Posted 29/11/10 02:43 AM Author Share Posted 29/11/10 02:43 AM Thanks guys for all your info, been very helpfull,off to put in a fuel pump nowpretty straight forward, quite a bit more noisy than the standard one Link to comment Share on other sites More sharing options...
