Sjorzie Member 27 Member For: 15y 2m 26d Posted 15/11/10 06:59 AM Share Posted 15/11/10 06:59 AM Hey everyoneI have a BA XR6T, have put a bigger cooler and x3 generic tune on it. before I get the custom tune done I have been told to do the valve springs injectors and fuel pump. what power could I expect, or othe people getting ? what size injectors should I get?thanks guys Link to comment Share on other sites More sharing options...
Worm A much better forum Silver Donating Members 3,808 Member For: 16y 6m 24d Gender: Male Location: Victoria Posted 15/11/10 08:10 AM Share Posted 15/11/10 08:10 AM What is it? Auto or manual?What cooler?You will need to do cat as well if you want around 300rwkw, although then your auto will die or just gearbox if 5 speed manual...But generally, valve springs, fuel pump, cat, cooler and injectors should see 300rwkw... Depending on how much boost standard actuator will hold...Next step is actuator and turbo wastegate mod... Will see around 330-40... Link to comment Share on other sites More sharing options...
Sjorzie Member 27 Member For: 15y 2m 26d Posted 15/11/10 09:11 AM Author Share Posted 15/11/10 09:11 AM yeah it is an auto. I would be happy with somthing closer to 300 Link to comment Share on other sites More sharing options...
Sjorzie Member 27 Member For: 15y 2m 26d Posted 15/11/10 09:29 AM Author Share Posted 15/11/10 09:29 AM are the valve springs fuel pump injectors and the tune more than a days work for the garage ? Link to comment Share on other sites More sharing options...
Henz Tampon inserted, Auto Acquired, next purchase a new handbag Donating Members 9,946 Member For: 16y 10m 27d Gender: Male Location: Vic Posted 15/11/10 10:08 AM Share Posted 15/11/10 10:08 AM Valve springs are a full day, Probably day and a half to finish it. You'll need the tuner to install the injectors though as it won't run well with them. Link to comment Share on other sites More sharing options...
Sjorzie Member 27 Member For: 15y 2m 26d Posted 16/11/10 08:29 AM Author Share Posted 16/11/10 08:29 AM Valve springs are a full day, Probably day and a half to finish it. You'll need the tuner to install the injectors though as it won't run well with them.thanks for the info guys Link to comment Share on other sites More sharing options...
Sjorzie Member 27 Member For: 15y 2m 26d Posted 16/11/10 09:16 AM Author Share Posted 16/11/10 09:16 AM we now install the NEW WALBRO GSS340 as we have found the GSS340 to work better in FORD BA, BF and FG models as it has a larger inlet for better fuel pick up.is this true guys ? better than the GSS341 ? Link to comment Share on other sites More sharing options...
GOLDIE My new toy Lifetime Members 5,344 Member For: 21y 9m 25d Gender: Male Location: stanthorpe wine capital of qld. Posted 16/11/10 09:17 AM Share Posted 16/11/10 09:17 AM if it takes a tuner a day to do the valve springs they arent very good at it.2 to 3 hours is all you need I have done over 30 sets and it is not a days work.Ian Link to comment Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 8m 19d Gender: Male Location: @ my laptop Posted 16/11/10 09:28 AM Share Posted 16/11/10 09:28 AM is this true guys ? better than the GSS341 ?340,341 or 342 they all flow the same Link to comment Share on other sites More sharing options...
Sjorzie Member 27 Member For: 15y 2m 26d Posted 16/11/10 09:48 AM Author Share Posted 16/11/10 09:48 AM Thanks ratter and goldie ,would these do the job for the setup above ? SIEMENS 840CC DEKA 80 Link to comment Share on other sites More sharing options...
