juggernaut Member 71 Member For: 16y 26d Posted 15/11/10 04:43 AM Share Posted 15/11/10 04:43 AM (edited) Garrett has extended the new GTX range of its turbos to the 3071 3076 and 3582.Refer to the garrett website for the comp maps and hp potential.GTX3076 gets close the the existing GT35 in flow. So existing GT35 hp potential with less lag. GTX3076 rated at up to 640hpGTX3582 would be a worthwhile upgrade with more flow than the existing GT35. Should slot straight into the stock exhaust housing too. GTX3582 rated at up to 750hp.Both offer some serious hp potential.No doubt these will find there way into Turbo 6 engine bays over time. Would love to see some results.Cheers. Edited 15/11/10 04:53 AM by juggernaut Link to comment https://www.fordxr6turbo.com/forum/topic/71662-anyone-likely-to-try-the-new-garrett-gtx-turbos/ Share on other sites More sharing options...
Henz Tampon inserted, Auto Acquired, next purchase a new handbag Donating Members 9,946 Member For: 17y 3m 15d Gender: Male Location: Vic Posted 15/11/10 04:51 AM Share Posted 15/11/10 04:51 AM How much extra HP can the GTX35 make, and how does it bring it on compared to the GT35R?Althoug I thought turbo peak hp ratings were always just a guide and people have pushed past them, out of the turbos rated effiency but still making power. Link to comment https://www.fordxr6turbo.com/forum/topic/71662-anyone-likely-to-try-the-new-garrett-gtx-turbos/#findComment-1055965 Share on other sites More sharing options...
juggernaut Member 71 Member For: 16y 26d Posted 15/11/10 05:02 AM Author Share Posted 15/11/10 05:02 AM (edited) For some reason I can't see the GTX comp maps on my computer on the turbo by garret website - but can see the ordinary comp maps. However, based on a post on skylinesau the comp maps for the GTX3076 and GTX3582 are wider (more flow) and higher - more flow at higher boost levels.Given the turbo falcon uses a 1.06 ex a/r exhaust housing (from memory) you will likely see the higher end of the hp ratings of these turbo's.....and maybe more as you've pointed out.The main difference I can see is that these turbos use a billet machined comp wheel. Edited 15/11/10 05:03 AM by juggernaut Link to comment https://www.fordxr6turbo.com/forum/topic/71662-anyone-likely-to-try-the-new-garrett-gtx-turbos/#findComment-1055970 Share on other sites More sharing options...
bcl Toughest BA Turbo Lifetime Members 3,408 Member For: 22y 6m 11d Gender: Male Location: Sydney Posted 15/11/10 05:30 AM Share Posted 15/11/10 05:30 AM 3582 runs a smaller compressor wheel than than the 35R, but due to lighter billet wheel gives better spoolup. Same turbine.750HP rating of 3582 seems a little ambitious; maybe the 3586 with the 1.06 housing.I've been looking at Precision & FP billet versions of these lately for a 2.6L motor. Good to see Garrett getting their act together regarding billet wheels for smaller turbos, rather than the web misinformation recently informing that there was no advantage of cast over billet wheel.Brian Link to comment https://www.fordxr6turbo.com/forum/topic/71662-anyone-likely-to-try-the-new-garrett-gtx-turbos/#findComment-1055976 Share on other sites More sharing options...
juggernaut Member 71 Member For: 16y 26d Posted 15/11/10 06:54 AM Author Share Posted 15/11/10 06:54 AM (edited) TurboByGarrett.com - Catalogsee the above link - 82.5mm comp wheel and rated to 750hp...only time will tell whether it can flow this much hp though...maybe with E85.Edit looks like the GTX has a slightly bigger inducer and exducer 58 trim) according to specs than the 'normal' GT35's. Edited 15/11/10 06:58 AM by juggernaut Link to comment https://www.fordxr6turbo.com/forum/topic/71662-anyone-likely-to-try-the-new-garrett-gtx-turbos/#findComment-1055988 Share on other sites More sharing options...
Dirty32 Legendary member!! Donating Members 1,739 Member For: 18y 5m 13d Gender: Male Location: Dianella, West Oz Posted 15/11/10 07:52 AM Share Posted 15/11/10 07:52 AM Isnt Karl from Hiro using a GTX42 or 45??I wonder what his experiences are and what benefit, whether by way of peak power, earlier spool or even fatter midrange he has seen over others with similar mods and just a standard GT42/45...Karl???? Link to comment https://www.fordxr6turbo.com/forum/topic/71662-anyone-likely-to-try-the-new-garrett-gtx-turbos/#findComment-1055994 Share on other sites More sharing options...
RIP_HSV HOON Member 1,636 Member For: 15y 3m 20d Gender: Male Location: W.A Posted 15/11/10 08:09 AM Share Posted 15/11/10 08:09 AM Could possibly be going to a GTX42 in the near future if 4094 off another forum member falls through, have read good reports on the GTX Range including earlier spool and more power through mid/top end!! Link to comment https://www.fordxr6turbo.com/forum/topic/71662-anyone-likely-to-try-the-new-garrett-gtx-turbos/#findComment-1056002 Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 18y 4m 28d Gender: Male Location: SW Sydney Posted 15/11/10 10:35 AM Share Posted 15/11/10 10:35 AM From what I've seen with the bigger frame GTX turbos on falcons (Spiro's, Karls Braiden (I think)) there can only be good things! The only thing I would be worried about is traction, we struggle with the standard BA/BF/FG turbos on normal tyres currently, going to something that spools up even harder and earlier will equal powerskids while going to the shops I think! I know of a very convincing result on a smaller engine with the Precision Turbo too Brian - 420-odd rwkw on an SR20 running E85: Link to comment https://www.fordxr6turbo.com/forum/topic/71662-anyone-likely-to-try-the-new-garrett-gtx-turbos/#findComment-1056060 Share on other sites More sharing options...
juggernaut Member 71 Member For: 16y 26d Posted 15/11/10 11:21 AM Author Share Posted 15/11/10 11:21 AM (edited) I know of a very convincing result on a smaller engine with the Precision Turbo too Brian - 420-odd rwkw on an SR20 running E85: Yes PJ's car held an Australian drag record for an s13 for a short while - low 10 secs with street radials, manual box, E85 and a Garrett 3076. Then went TO4Z into the 9's.....now going back to something more streetable - Precision turbo you say?. Edited 15/11/10 11:23 AM by juggernaut Link to comment https://www.fordxr6turbo.com/forum/topic/71662-anyone-likely-to-try-the-new-garrett-gtx-turbos/#findComment-1056074 Share on other sites More sharing options...
dansedgli Member 214 Member For: 21y 5m 24d Posted 15/11/10 11:25 AM Share Posted 15/11/10 11:25 AM Does anyone know if these are any different to the billet turbo range of turbos? Link to comment https://www.fordxr6turbo.com/forum/topic/71662-anyone-likely-to-try-the-new-garrett-gtx-turbos/#findComment-1056076 Share on other sites More sharing options...
