  • Replies 51
  • Member For: 17y 11m 22d
Hey Guys,
Apologies for the late reply. I just finished 1000Kms roughly 2 weeks ago after installing this kit on my BF Mk II Ghia (as you can tell I hardly drive the thing). The external cooler is great. I have had no dramas with it at all apart from leaking factory o-rings that needed replacing to prevent oil leaks.
I drove my car just as I used to in the past (took it easy till the engine water temp was just past the 1/4 mark -- mine usually does this in the first 2kms or so) and it hasn't thrown up any error codes. I did come across some real warm 35*C+ days where I was in the city start-stop cycle and also a few cooler 6*C days and am glad to report that the ZF did not struggle at all. In my opinion, it is a mod worth every penny and for a few $$ outlay, it is cheap insurance. I haven't taken the car to a track, so this area is still untested. But, in saying that I did do some 'spirited' driving (about an hours worth in 28*C weather) on a private road in a mate's farm and everything worked like it should.
My turbo is still being tuned with the new mods and I have done roughly 550Kms with it with the same kit installed and with the same result (although I did not push it as hard as the NA -- since I did not have a retune). I will update this post once I get my turbo back and get a chance to push it a bit.
Cheers,
AJ
Edited by Phooned
  • Member For: 14y 10m 19d
I have this one in my car too. Its set up as an external cooler. Its a b*****d to fit according to the mechanic that fitted it, but so far no issues. Its only been on a couple of weeks at this stage.
  • Member For: 16y 4m 19d
  On 22/02/2011 at 1:56 AM, Phooned said:
Hey Guys,
Cheers,
AJ
Thanks AJ.
So just to confirm, there's no more heat exchanger, just the external cooler?
Cheers.
  • 3 months later...
  • ʎǝʞuoɯ ɹoıuǝs
  • Member For: 16y 5m 13d
after a few months were there any issues with these coolers on the ZF?
  • 2 weeks later...
Hey mate...I can confirm my setup is still going strong. I have the occasional ZF clunk when cold (did the same with the heat exchanger previously as well). However, once warmed up, I havent had any drama so far. My turbo is driven fairly hard as well.
Edited by Phooned
  • ʎǝʞuoɯ ɹoıuǝs
Sweet. Where did u mount the core? What size and length lines did u use?
There are kits on eBay by seller Furious8 I'm thinking of getting one and mounting next to intercooler
  • 2 weeks later...
