Moose Member 185 Member For: 17y 1m 30d Gender: Male Location: Ipswich, QLD Posted 08/11/10 04:29 AM Share Posted 08/11/10 04:29 AM (edited) Hey everyone,My F6 is currently down at Ford getting looked at for suspected gearbox issues - the car still drives normally, but the gearbox makes a very loud whining sound and slips very bad, mind you all of this happened in a matter of 5 hours. Whine started very low, then got a bit louder, louder, louder, then started to slip n carry on - I had to drive it home but it wasnt far once it started slipping. Also, just before it started to slip, the D symbol in the dash started to flash and kept flashing all the way home, but when I turned it back on to move it later at home, it wasnt flashing.I also have the issues with my manual select mode not working 100%, apparently because ive changed my diff gears? I've been told the 6 speed manual will have no issues with diff gears (yes I know I'll have to change them again for the manual) and would also be a cheaper option over the zf replacement.My questions are, is my gearbox about to die? And if so, would a 6 speed be a better option? Car is an 06 BF F6.Cheers, Mitch Edited 08/11/10 04:33 AM by Moose Link to comment https://www.fordxr6turbo.com/forum/topic/71516-help-zf-issues/ Share on other sites More sharing options...
ScatterBrain Donating Members 316 Member For: 16y 14d Gender: Male Location: Brisbane Posted 08/11/10 08:08 AM Share Posted 08/11/10 08:08 AM What sort of power are you running? Also from memory a flashing "D" means the trans is overheating. Link to comment https://www.fordxr6turbo.com/forum/topic/71516-help-zf-issues/#findComment-1054009 Share on other sites More sharing options...
Pazzo Donating Members 11,132 Member For: 14y 7m 25d Gender: Male Posted 08/11/10 08:18 AM Share Posted 08/11/10 08:18 AM for the price of a zf rebuild, you could get a built auto like, c4,c9,turbo400,powerglide,and have a stally as well. Link to comment https://www.fordxr6turbo.com/forum/topic/71516-help-zf-issues/#findComment-1054017 Share on other sites More sharing options...
CCCC miso xr6 Donating Members 317 Member For: 16y 6m 7d Posted 08/11/10 08:43 AM Share Posted 08/11/10 08:43 AM sorry to hear mate,sounds like the trans over heated,hope its not bad, but dam you got some nice wheels. Link to comment https://www.fordxr6turbo.com/forum/topic/71516-help-zf-issues/#findComment-1054034 Share on other sites More sharing options...
our06t Mmmmm......BOOST Member 3,135 Member For: 18y 1m 19d Gender: Male Location: central coast Posted 08/11/10 09:40 AM Share Posted 08/11/10 09:40 AM On 08/11/2010 at 8:18 AM, pazzo xr6t said: for the price of a zf rebuild, you could get a built auto like, c4,c9,turbo400,powerglide,and have a stally as well.sorry mate but I think you way off there , might cost the same for the box but a lot of other mods are required to fit any of those boxes , bell housings ,ecu , tailshaft etc , try sending Rapid a pm and have a chat I was talking to him rcently about rebuilding these ZF's , if you real lucky it may have just lost some fluid and overheated . Link to comment https://www.fordxr6turbo.com/forum/topic/71516-help-zf-issues/#findComment-1054071 Share on other sites More sharing options...
Moose Member 185 Member For: 17y 1m 30d Gender: Male Location: Ipswich, QLD Posted 08/11/10 10:53 PM Author Share Posted 08/11/10 10:53 PM Ford confirmed the worst :( its cactus. The oil filter/pump in the gearbox seized or blocked up, causing the gearbox to stave for oil. End result, it now slips and is basically rooted and will need to be replaced.So not sure what to do, have the ZF rebuilt into a much tuffer box, or put the manual behind it? First quote for the manual conversion, walk in walk out with a 550kw clutch was $9k.... :\And will send Rapid a PM, Thanks for the help everyone And cheers for the comment on the wheels, haven't had em long (and scratched the front left putting the car on that fkn trailer!!!) Link to comment https://www.fordxr6turbo.com/forum/topic/71516-help-zf-issues/#findComment-1054207 Share on other sites More sharing options...
F6_Tornado F6+300+ Member 940 Member For: 20y 7m 8d Location: In The Ute Posted 08/11/10 11:36 PM Share Posted 08/11/10 11:36 PM On 08/11/2010 at 10:53 PM, Moose said: Ford confirmed the worst :( its cactus. The oil filter/pump in the gearbox seized or blocked up, causing the gearbox to stave for oil. End result, it now slips and is basically rooted and will need to be replaced.If It seized the pump it wont go anywhere let alone slip. Never seen one yet with the pump seized. Seen plenty cooked and plenty starved for oil due to blocked filter and they slip like crazy.Given to the right people I cant see it costing you much at all. Ford don't rebuild them so they will just say its screwed and put in a new one at your expense. If you were in WA I'd have a look at it for you but Sunny QLD is a long way from WA... Good luck. Link to comment https://www.fordxr6turbo.com/forum/topic/71516-help-zf-issues/#findComment-1054214 Share on other sites More sharing options...
our06t Mmmmm......BOOST Member 3,135 Member For: 18y 1m 19d Gender: Male Location: central coast Posted 09/11/10 01:54 AM Share Posted 09/11/10 01:54 AM was trying to remember your user name last night just couldn't think of it .the man above is the one to talk too moose. Link to comment https://www.fordxr6turbo.com/forum/topic/71516-help-zf-issues/#findComment-1054234 Share on other sites More sharing options...
kyle173 Donating Members 774 Member For: 16y 7m 14d Gender: Male Location: brisbane Posted 09/11/10 02:28 AM Share Posted 09/11/10 02:28 AM send hiro a message I know they are building there gearboxs soon and its pretty cheap and its brisbane too Link to comment https://www.fordxr6turbo.com/forum/topic/71516-help-zf-issues/#findComment-1054237 Share on other sites More sharing options...
Moose Member 185 Member For: 17y 1m 30d Gender: Male Location: Ipswich, QLD Posted 09/11/10 10:41 PM Author Share Posted 09/11/10 10:41 PM Well I've decided im going to put the manual in it! Solves alot of issues and will cost me about $6.5k thru my mechanic walk in walk out all new parts etc.Will keep you guys posted on how she goes, kinda excited for the manual - anything I should be worried about? lol Link to comment https://www.fordxr6turbo.com/forum/topic/71516-help-zf-issues/#findComment-1054501 Share on other sites More sharing options...
