  • Member For: 15y 2m 4d
well I just got the engine installed with 3 month warranty so will be giving dynomite a call monday morning to see what they can do. Just annoying me really bad, car was off road for 5 months and now its playing up again. It just never ends :stirthepot:
  • Member For: 18y 7m 8d
as they say "you play you pay",, its never ending.. if its under warranty then as you said take it back
  • Member For: 21y 8m 3d
If its all stock (ie: no tune at all) then this could be either the TPS on its way out (revs bouncing/ engine hunting) or its normal as there was always an inherant problem with low rpm/stalling on the BA series turbo's.
In the day (LOL) we used to either just clean the throttle body regularly (lots) with carb cleaner or another small mod was to drill a 0.5-1mm hole in the butterfly to allow the engine to idle that extra 50rpm, this can always be filled with one tac weld if nothing noticable is happening.
The only other fix was a tune to raise idle or play with voltage clamps or whatever tuners do :roflmbo:
Well I went to start it yesterday and it wouldnt start, so I got a new one and its been great since. Mechanic said cuz my car was doing nothing for so long while the engine was stuffed and he said probably had dead cells. So hopefully it has somehow fixed the problem. :s
