  • Banned
  • Member For: 16y 8d
  On 06/11/2010 at 4:10 AM, icer said:
you need to cut the wires and extent them. I have the same kit. My plazmaman cooler piping has a place I put my boost sensor on the piping just before the cooler core on the passanger side. I reran the cables to reach over there. Cheeck your cooler pipes as there should be a place to put the sensor.
What are you guys talking about? If I'm not mistaken this guy said he has a 4" intake and battery relocation kit?????? WTF has the air intake to the turbo and the battery relocation got to do with the boost pressure sensor fitted on the UBP going to the factory cooler?????????
Mika are you also fitting an intercooler kit as well or do you have the factory cooler?
  • Replies 50
Posted Images
  • Member For: 18y 9m 30d
Yea sorry, also a nizzy cooler
Where do I fit the sensor to, Cold side pipes or Hotside? Is it ok to drive around as is?
*Beep*, the cooler is from there stage 2 kit, which is meant to have a plenum.. I dont have a plenum so I got cold side pipes off plazmaman that runs from the rubber nizpro pipe that goes under the headlight to the TB.. The plazma pipes had a bit welded on but that was for a bov, which I had welded shut..
Everything is sorted except for the boost sensor thingy... I cant give it any beans anyway cause its needed a retune before the new bits went on today..
  • Banned
Well the Nizpro kit has the boost sensor attached to the throttle body reducer pipe that is used for their plenum as in their diagram in the instructions. The plazmaman kit has the boost sensor mounted on the cold side pipe that goes from the outlet of the intercooler to the silicon connector that goes under the headlight. If you do not have this you need to have a boost sensor boss welded in somewhere in your pipes.
  • Member For: 17y 4m 20d
When you have the Nizzy cooler kit without plenum they give you a little alloy block that mounts where the old ubp was and the boost sensor fits into it. A vac line then runs off the block to the cold side pipe to pick up pressure.
  • Member For: 18y 10m 22d
  On 08/11/2010 at 9:00 AM, ebxmple said:
Nizpro might be able to help you as I am sure quite a few upgrade from stg1 to stg2,so they might have a spare laying round. I might have my old one in the shed so if I remember I will have a look.
thanks ebxmple
