  • Waiting for the 1st N/A 12!
  • Member For: 17y 3m 28d
Flash and Edit tune will always increase your RWKW's regardless of any mods!
  • Replies 40
Posted Images
  • Member For: 15y 8m 22d
Sorry, Probably wasn’t clear in my post. Yes you will make more power with a tune. My guess is you will make 300-315rwkw with a tune.
What I was trying to explain is putting larger injectors in will not make any difference unless you have other mods to support it. In this case the car will not make over 340rwkw with just a tune and injectors, so why change them?
:spoton:
Ben
Edited by XYZ
  • loitering with intent
  • Member For: 21y 9m 20d
Disagree, I would have bigger squirters always over maxing out duty cycle on stockers
  • You are a dead set goose
  • Member For: 19y 6m 9d
More importantly would be the rwkw increase from the baseline reading. Mine did 279rwkw stock and then 302rwkw after a tune so just over a 20rwkw increase. I didn't do injectors but the stock ones started leaning out at 300rwkw. Good luck :spoton:
  • Member For: 19y 2m 19d
Good to hear R-Spec. Thanks for the input Ben, hope I don't start popping Intercooler pipes, didn't really want the expense of doing the cooler just yet, but maybe down the track
  • Legendary member!!
  • Member For: 18y 4m 17d
You will start popping intercooler pipes if your upping the boost...!
You dont have to replace the cooler itself, but you should do the piping.
Shouldnt cost you too much!
Id say 319rwkw.
  • Member For: 17y 2m 19d
Pitlane has fg replacement pipes for $450, and it wouldn't be to hard just to replace the pipes yourself or sweet f a labour.
  • HOON
  • Member For: 15y 2m 24d
+1.... 305 rwkw's!!
