  • Member For: 17y 10m 3d
heres my 1997 turbo el falcon
specs:
stock au 4l block
stock au crank
howards conrods
cp pistons
custom ported sohc head
stainless valves
surecam custom grind billet camshaft
6boost turbo manifold
billet turbos sb70-gtq turbo
tial 44mm gate
nizpro plenum
4" exhaust
2" screamer
autronic sm4 ecu
autronic 500r cdi
6x bocsh coils
indy blue injectors
2x 044 pumps
1/2 fuel line
billet fuel rail
610x310x110 ARE intercooler
tremec tko600 5speed gearbox
strange 3.7:1 9" diff with eaton trutrack center
it was tuned on the weekend and it ended up with 543rwkw/729rwhp on 23psi with e85 fuel
cheers
https://www.fordxr6turbo.com/forum/topic/71407-543rwkw-el-gli/
  • Member For: 17y 5m 12d
I agree, that is certainly not something you see every day. You gotta run it down the 1/4 and see what the time and mph are!! Good stuff, woulda been quite the project. :stirthepot:
I'm taking a stab here because there's no RPM on the graph, but assuming that peak power figure is at 4500 RPM (my guess)
Googling shows that T(Nm) = P(kW) x 9543 ÷ RPM
so 543.8 * 9543 ÷ 4500 = 1153Nm? Would have peak torque somewhere else I'd think? Can't figure that one out due to sliding RPM to power ratio.
In short, lots!
Edited by -SteveR-
Oh yeah and you have more power than the TT V8 Statesman that got posted recently too hahaha :)
  • Member For: 17y 11m 11d
I don't even wanna know whats gonna happen to the GTE.
