bjcrown Donating Members 182 Member For: 19y 1m 9d Posted 31/10/10 05:21 AM Share Posted 31/10/10 05:21 AM Guys,I have a BA MKII 4sp Auto. Looking into getting some spark plugs.I'm thinking of purchasing NGK BKR6EIX but a friend of mine mentioned to best get spark plugs from Ford for a BF Turbo as they are pre-gapped to .9mm and a small adjustment is required to .8mm. Also the Ford plugs are best suited to the coils??? Is this true?I believe the spark plug part number for the BF's is AGSP22YE09. These are Denso plugs yes? If so, what are the Denso part number? Do they come pre-gapped to .8mm?Is this correct?Are these iridium type plugs and how long (kms) do they last?What do you guys reckon NGK's or Ford?Thanks Link to comment Share on other sites More sharing options...
Redback Banned 236 Member For: 15y 5m 16d Gender: Male Location: Blacktown NSW Posted 31/10/10 06:02 AM Share Posted 31/10/10 06:02 AM BKR6EIX NGK IRIDIUM Link to comment Share on other sites More sharing options...
bjcrown Donating Members 182 Member For: 19y 1m 9d Posted 01/11/10 10:07 PM Author Share Posted 01/11/10 10:07 PM So you guys reckon NKG's are the way to go (other than Fords/Motorcraft/Denso BF plugs)?How long do the NKG's last? Link to comment Share on other sites More sharing options...
Robos F6 Donating Members 407 Member For: 15y 8m 26d Gender: Male Location: Vic Posted 02/11/10 04:17 AM Share Posted 02/11/10 04:17 AM The NGK BKR6EIX are allready gapped to 0.8mm Link to comment Share on other sites More sharing options...
boost69 Donating Members 737 Member For: 19y 6m 9d Posted 02/11/10 04:52 AM Share Posted 02/11/10 04:52 AM Im using the Motorcraft ones which are manufactured by Denso... from memory they are pregapped to 0.8mm Link to comment Share on other sites More sharing options...
Redback Banned 236 Member For: 15y 5m 16d Gender: Male Location: Blacktown NSW Posted 02/11/10 05:31 AM Share Posted 02/11/10 05:31 AM Mate just use the NGK. Almost every high HP engine on here uses them and they have never failed. They are good for about 80000km but I change them regularly. By reducing the spark gap you are also limiting the amount of energy the coil has to use to jump the gap. This will give you more voltage reserve and duration when you need it. Link to comment Share on other sites More sharing options...
Adrian_F6 Large Member Member 551 Member For: 16y 2m 21d Gender: Male Location: In The Sticks Posted 03/12/10 01:05 PM Share Posted 03/12/10 01:05 PM if that's the go, why not gap them even closer? like .6 or .7 or something? Link to comment Share on other sites More sharing options...
Adrian_F6 Large Member Member 551 Member For: 16y 2m 21d Gender: Male Location: In The Sticks Posted 08/12/10 09:29 AM Share Posted 08/12/10 09:29 AM bump? Link to comment Share on other sites More sharing options...
jimmixr Donating Members 686 Member For: 14y 3m 9d Posted 08/12/10 09:47 AM Share Posted 08/12/10 09:47 AM Adrian.. closing the gap does promote a stronger spark and with increased boost helps eliminate the spark being blown out before ignition of the cylinder.But in saying that going too small doesnt expose enough spark to ignite in the fuel charge..So basically its a fine line.. and .8 is about it. I have seen some guys use smaller gaps but were talking insane boost and even crazier ignition system that would light a small townHope this helpsCheers Link to comment Share on other sites More sharing options...
bloosted Cruise Control 1,383 Member For: 18y 11m 22d Gender: Male Location: Adelaide Posted 08/12/10 09:53 AM Share Posted 08/12/10 09:53 AM any smaller affects idle quality as well Link to comment Share on other sites More sharing options...
