Hub Centric Rings Or "Bcl"
djkice
  • Boost Addict
  • Member For: 16y 5m 3d
Not sure what happened to mine but I now need replacements.
I have 20" aftermarket wheels and fg xr6t..
is there one spcific for all fg or is it as per wheel?
where would I find these ?
  • Member For: 16y 9m 5d
Are you referring to those plastic rings that go on the hub tomake a tighter fit?
Any tyre shop should have them. Bob Jane wanted $3 a ring! Tyre factory give them away for free.
  • Member For: 15y 9m 27d
It is as per wheel. The Falcons centre bore is 70.5mm.
My Enkeis had a centre bore of 76mm, so had to get some custom machined to have an outside diameter of 76mm and inside diameter of 70.5mm.
Most wheels will have a centre bore of 73.1mm, so you will need to find some that have an outside diameter of 73.1mm and inside of 70.5mm. I would also reccomend trying to get some aluminium ones as they are better than the plastic type.
http://cgi.ebay.com/ebaymotors/Metal-Hub-Centric-Hubcentric-Rings-73x70-5-73-70-5-_W0QQcmdZViewItemQQhashZitem3361cc055eQQitemZ220684092766
or
http://cgi.ebay.com/ebaymotors/Hub-Centric-Rings-73-1-70-5-mm-_W0QQcmdZViewItemQQhashZitem27aa3803f7QQitemZ170359522295QQptZLHQ5fDefaultDomainQ5f100
Edited by winstor
  • A much better forum
  • Member For: 16y 5m 2d
Yeah! Plastic is sh*t! They can warp and make your wheels feel like they are not balanced!!!
