3.5 Inch Dump With Small Screamer
southside
  • Banned
  • Banned
  • Member For: 14y 5m 17d
screamer is exactly that... VTA and scary loud enough to piss off anyone nearby !
plumbed back in to lower zost is just a rerouted wastegate pipe or dump pipe... totally different due to noise ! similar in regards to VTA bov and recirc... but noisier !
  • Replies 24
  • Member For: 17y 9m 3d
I think that's it! and yeh my car sits lower than any others! u cant fit your fingers between the gaurds front and rear! and is I <3 Bananas loud with my system haha and touch wood ive never been hassled! so all good! hope it stays that way!
Sounds good but boosts the "hoon" factor up about a million points.
  • Moar Powar Babeh
  • Member For: 19y 5m 6d
And sound awesome when running decent boost, but under 13-14psi sound pretty average.
What boost does a stock WRX run? there one that lives near me with a screamer and
it sounds like a wet fart..........god it sounds awful :bowdown:
  • Banned
  • Banned
stock wrx is circa 1 bar on pre 2000 td05 cars(14psi) depepnds onj diameter of pipe and also the cubes of the motor help ! skylines being 2.5/2.6L but had a wrx running 22psi, animal ! :bowdown:
Edited by rab
  • 1 month later...
  • Member For: 15y 8m 19d
If you fit a screamer pipe on the wastegate outlet (Provided you keep the waste gate gases and exhaust gases separate) it helps to stop turbulence caused by the sudden opening of the waste gate flapper hence helping flow through the exhaust. I would plumb the screamer pipe back into the exhaust before the cat. unless you want the raw sound from the exhaust as the waste gate cracks open. :3gears:
