AIM-300 SUPERLAP 2011 Member 158 Member For: 17y 9m 14d Gender: Male Location: townsville Posted 23/10/10 07:47 AM Share Posted 23/10/10 07:47 AM hey guys have a drama. im currently doin an oil change in my gearbox (t56 as above) and have filled it with exactly 4l from the factory filler point.now from what I have read on here, im supposed to put 4.8l in it and fill it from the reverse switch. problem is I can get to iit as there is a heap of casting around it and I cant get a spanner in there and I can get a socket in there coz the loom that comes out of the switch comes out on an angle. I suppose my question is, is 4l enough in these boxes and also how have the rest of you removed the reverse switch to fill it or 3 is it possible to put the remainder .8l in through the shifter like I have filled all my other cars (except my gtr, funny story that one... but anyway.) yeah any help would be appriciated.cheers adam Link to comment Share on other sites More sharing options...
RHR BOOST Moderating Team 5,698 Member For: 21y 4m 2d Gender: Male Location: Southern Highlands NSW Posted 23/10/10 08:01 AM Share Posted 23/10/10 08:01 AM The extra .8 is to make the box quieter as the inline 6 has some weird harmonics, which causes the common roll over noise from the box. IN short 4l is fine Link to comment Share on other sites More sharing options...
Wenier Donating Members 1,736 Member For: 14y 11m 20d Gender: Male Location: Christchurch, New Zealand Posted 23/10/10 09:53 AM Share Posted 23/10/10 09:53 AM 4.85L is the correct amount that is meant to go in. You could try a crows foot instead of a spanner. Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 2m 11d Gender: Male Location: Perth Posted 23/10/10 11:34 AM Share Posted 23/10/10 11:34 AM Jack up the passengers side only and put the other 800ml in the normal fill hole , dont worry about the reverse. Link to comment Share on other sites More sharing options...
Smoke them tyres Member 557 Member For: 17y 17d Gender: Male Location: Brisbane Posted 23/10/10 01:09 PM Share Posted 23/10/10 01:09 PM That would be a lot of jacking. Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 2m 11d Gender: Male Location: Perth Posted 23/10/10 02:06 PM Share Posted 23/10/10 02:06 PM Ive done it many times and its the best way. Obviously keep it safe and use stands. Link to comment Share on other sites More sharing options...
Wenier Donating Members 1,736 Member For: 14y 11m 20d Gender: Male Location: Christchurch, New Zealand Posted 23/10/10 10:58 PM Share Posted 23/10/10 10:58 PM How much of an angle does it need to get that last bit in? If your on the normal axle stands everyone buys from supercheap or repco are they maxed out? Link to comment Share on other sites More sharing options...
AIM-300 SUPERLAP 2011 Member 158 Member For: 17y 9m 14d Gender: Male Location: townsville Posted 23/10/10 10:59 PM Author Share Posted 23/10/10 10:59 PM cool, might go for a lash and see if in noisy. if it is ill jack it up on the side and top the rest up.thanks for your help guys Link to comment Share on other sites More sharing options...
TURBO4LT Member 1,533 Member For: 21y 4m 20d Gender: Male Location: NSW Posted 24/10/10 02:38 AM Share Posted 24/10/10 02:38 AM I just fill mine through the reverse switch, 4lts is all I use with no issues for the last 7 years with decent power levels. Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 19y 3m 15d Gender: Male Location: Perth Posted 24/10/10 02:56 AM Share Posted 24/10/10 02:56 AM The right angle wire and molded cover on the reverse switch is actually a plug that can be removed. It pulls straight off to reveal the two bullet terminal on the switch. With this removed you can us a spanner etc to remove the switch Link to comment Share on other sites More sharing options...
