Pazzo Donating Members 11,132 Member For: 14y 6m Gender: Male Posted 23/10/10 02:22 AM Share Posted 23/10/10 02:22 AM gday everyone 1 new here, have a 07 bf mk2 6t, has hdicooler,60pound injectors,ss growler,12psi acuator,flappermod,portedwastegate,full xforce exhaust,surgetank,16psi,xcal3, tuned by springy motors,makes low 340srwks. what I would like to know is it worth getting the head ported on our cars. personaly I dont know of any 1 who has, if it was done would you gain much,would it be hard to tune,is it worth doin,or is it 1 of those things on our cars that would be a waste of time. only reason I ask is cause those ls1 boys do head and cam package and get good gains. you know how it is trying to get the egde on everyone. Link to comment https://www.fordxr6turbo.com/forum/topic/71222-head-porting/ Share on other sites More sharing options...
Henz Tampon inserted, Auto Acquired, next purchase a new handbag Donating Members 9,946 Member For: 17y 1m 2d Gender: Male Location: Vic Posted 23/10/10 02:32 AM Share Posted 23/10/10 02:32 AM As far as I know there's no real gains to be had for street cars. Some people have done it in bigger builds, but the barra heads flow pretty well stock. Link to comment https://www.fordxr6turbo.com/forum/topic/71222-head-porting/#findComment-1049850 Share on other sites More sharing options...
power_slide Hitting the apex Donating Members 596 Member For: 16y 6m 4d Gender: Male Location: Miranda Posted 23/10/10 02:39 AM Share Posted 23/10/10 02:39 AM Head is good for 1000hp so it's not worth touching Link to comment https://www.fordxr6turbo.com/forum/topic/71222-head-porting/#findComment-1049851 Share on other sites More sharing options...
Benny Member 1,869 Member For: 21y 8m 16d Gender: Male Location: Newcastle Posted 23/10/10 03:41 AM Share Posted 23/10/10 03:41 AM For naturally aspirated engines porting can make good gains with air flow as the engine has to suck the air in. On forced induction motors it's not regularly done due to the air being pushed in and it being easier to just run few more psi to make the figures.Benny Link to comment https://www.fordxr6turbo.com/forum/topic/71222-head-porting/#findComment-1049856 Share on other sites More sharing options...
kyle173 Donating Members 774 Member For: 16y 5m 20d Gender: Male Location: brisbane Posted 23/10/10 04:15 AM Share Posted 23/10/10 04:15 AM how much for head porting? Link to comment https://www.fordxr6turbo.com/forum/topic/71222-head-porting/#findComment-1049862 Share on other sites More sharing options...
icer Banned 2,335 Member For: 15y 9m 4d Gender: Male Location: Aspendale, Vic. Posted 23/10/10 05:51 AM Share Posted 23/10/10 05:51 AM Dion tells me a ported xr6 head flows 30% better then a 2jz which is a plus! Link to comment https://www.fordxr6turbo.com/forum/topic/71222-head-porting/#findComment-1049888 Share on other sites More sharing options...
SPIKO Gold Donating Members 1,924 Member For: 20y 15d Gender: Male Posted 23/10/10 08:42 PM Share Posted 23/10/10 08:42 PM A standard XR6 head flows 30 to 40% better than a ported 2jz The benefits of porting correctly are not only in the power region, when we discuss flow this changes as the rpm does concurrently. If you have a serious bottom end porting & cams is a must for the following reasons;1. Increased flow and less restriction (Boost) allowing turbo to work less and create more power otherwise known as efficiency 2. Increased rpm speed or the amount of time required to reach a certain rpm 3. Increases in rpm in general.4. Less psi and heat in your plumbing, inter-cooler & inlet resulting in more consistent back to back power graphs.5. Decreases in fuel temperature resulting in better cylinder/combustion chamber cool down between ignitions etc.etc.An all out race ported xr6 head will flow 40 to 50% better than a 2jz ported head any and every day of the week Link to comment https://www.fordxr6turbo.com/forum/topic/71222-head-porting/#findComment-1050005 Share on other sites More sharing options...
qik1 Silver Donating Members 2,720 Member For: 16y 11m 11d Gender: Male Location: Loitering in SEQ Posted 23/10/10 10:01 PM Share Posted 23/10/10 10:01 PM Ive had mine done when we redid the engine but havent had a chance to see what type of difference its made but by all reports its definatly a positive move but by the list of your mods theres plenty more things that id spend my money on first. Perhaps look at a bigger I/c, plenum & intake kit. A good setup is worth its weight in gold & will help big time in the race for power but also in longevity because everything flows & cools alot better.I use all plazmaman/rapid systems gear & the results are speaking for themselves & others have had awesome results using p/w so either way you'll have win. Link to comment https://www.fordxr6turbo.com/forum/topic/71222-head-porting/#findComment-1050014 Share on other sites More sharing options...
