Guest XR09 Guests Posted 22/10/10 07:34 PM Share Posted 22/10/10 07:34 PM There is a BA/BF manual floaing around cyber space. Take half an hour to search and find it and use the manual. Only way you will save a lot of time and worry Link to comment https://www.fordxr6turbo.com/forum/topic/71194-intercooler-install-on-a-na/page/2/#findComment-1049804 Share on other sites More sharing options...
Wenier Donating Members 1,736 Member For: 15y 3m 18d Gender: Male Location: Christchurch, New Zealand Posted 23/10/10 09:33 AM Share Posted 23/10/10 09:33 AM Are you running a different intake manifold on other than the std one. Link to comment https://www.fordxr6turbo.com/forum/topic/71194-intercooler-install-on-a-na/page/2/#findComment-1049950 Share on other sites More sharing options...
zayd687 Member 74 Member For: 15y 3m 25d Posted 23/10/10 01:11 PM Author Share Posted 23/10/10 01:11 PM it hasnt crossed my mind , I would be upgrading the standard airbox sometime?why?is there another route I can take for the piping.. if nothing I was going to just cut a whole around 3 inch in diametre and join the pipes through there. Link to comment https://www.fordxr6turbo.com/forum/topic/71194-intercooler-install-on-a-na/page/2/#findComment-1049989 Share on other sites More sharing options...
Dimetime Member 11 Member For: 14y 11m 4d Posted 24/10/10 09:41 PM Share Posted 24/10/10 09:41 PM save yourself and dont do the cross over like the standard xr6t's, if you can get someone to send you a pic of a rapid set up or something similar? youll see the airbox doesnt have to go where it normally does and youll get quicker spool up! Link to comment https://www.fordxr6turbo.com/forum/topic/71194-intercooler-install-on-a-na/page/2/#findComment-1050236 Share on other sites More sharing options...
zayd687 Member 74 Member For: 15y 3m 25d Posted 25/10/10 12:51 AM Author Share Posted 25/10/10 12:51 AM On 24/10/2010 at 9:41 PM, Dimetime said: save yourself and dont do the cross over like the standard xr6t's, if you can get someone to send you a pic of a rapid set up or something similar? youll see the airbox doesnt have to go where it normally does and youll get quicker spool up!HMM REALLY????what you mean rapid setup ? is that a particular brand? where would I be moving the airbox too?this sounds mroe interesting... I will draw you guys an example of what im doing for now. Link to comment https://www.fordxr6turbo.com/forum/topic/71194-intercooler-install-on-a-na/page/2/#findComment-1050258 Share on other sites More sharing options...
zayd687 Member 74 Member For: 15y 3m 25d Posted 25/10/10 01:15 AM Author Share Posted 25/10/10 01:15 AM see my diagram of what im doing so far.. I can change thisim using stock oem piping as its flexible and easy to use.until I upgrade the cooler later on. Link to comment https://www.fordxr6turbo.com/forum/topic/71194-intercooler-install-on-a-na/page/2/#findComment-1050263 Share on other sites More sharing options...
zayd687 Member 74 Member For: 15y 3m 25d Posted 25/10/10 01:18 AM Author Share Posted 25/10/10 01:18 AM On 23/10/2010 at 9:33 AM, Wenier said: Are you running a different intake manifold on other than the std one.didnt read your question well.im using the standard intake plenum. im budgeting my costs to have her up and running before I move onto introduce the plasma and upgrade the airbox, cooler , injectors all during the time of tuning.so far the car has cams and with the turbo shud make some interesting power itself. Link to comment https://www.fordxr6turbo.com/forum/topic/71194-intercooler-install-on-a-na/page/2/#findComment-1050264 Share on other sites More sharing options...
sexual harrassment panda I see a red door and I want to paint it black Donating Members 5,919 Member For: 15y 6m 11d Gender: Male Location: Far north queensland Posted 26/10/10 05:44 AM Share Posted 26/10/10 05:44 AM if I was you I'd save and save and save and then do it all at once. Full cooler/piping kits come up for sale on here quite often. if you can save til you can afford one with a plenum or a throttle body relocation then you'll be heaps better off. Link to comment https://www.fordxr6turbo.com/forum/topic/71194-intercooler-install-on-a-na/page/2/#findComment-1050611 Share on other sites More sharing options...
Wenier Donating Members 1,736 Member For: 15y 3m 18d Gender: Male Location: Christchurch, New Zealand Posted 26/10/10 09:08 AM Share Posted 26/10/10 09:08 AM Id say at least put the short intake with pod where the battery originally is and relocate the batt, then run the pipe to the cooler the normal way which then out the cooler on opposite side and straight up to the manifold. Then change that cold side pipe when you do the plenum to suit new plenum. Link to comment https://www.fordxr6turbo.com/forum/topic/71194-intercooler-install-on-a-na/page/2/#findComment-1050687 Share on other sites More sharing options...
zayd687 Member 74 Member For: 15y 3m 25d Posted 26/10/10 10:32 PM Author Share Posted 26/10/10 10:32 PM Hi wenieris the above what you mean? sorry for the dodgy diagram.1) where the original air intake box/pipe was, use that way to put in new intercooler hoses to the intercooler through the passenger headlight.2) use the other intercooler exit and attach the cooler through driver headlite to turbo3) attach plastic pipe from std xr6 cross over to turbo as per original4) run new pipe to battery tray and attach a pod.is this generally what you meant? Link to comment https://www.fordxr6turbo.com/forum/topic/71194-intercooler-install-on-a-na/page/2/#findComment-1050782 Share on other sites More sharing options...
