  • Replies 38
  • Banned
  • Banned
  • Member For: 14y 7m 23d
after a bit of readign here and there, I would probably say its normal. its certainly no skyline gearbox for smoothness and sound/feel but its getting better the more I use it ! will change the oil myself and engine too if they don't change it at 3000klms.
  • It's not a MKI!
  • Member For: 16y 10m 16d
I bet it's low on oil. Ask them to drain it and see if it's got close to 5L in it.
If it hasn't, it needs 4.85L as per the workshop manual.
Mine made a similar noise for ages until I was made aware that the oil capacity was required to be 4.85L for the I6.
Since filling it with the correct quantity, no more noise.
Edit: see here for more detail. http://www.fordxr6turbo.com/forum/index.php?showtopic=70893
Edited by PHANTMXR6
  • Member For: 14y 8m 19d
Is the Tremec, not the same as 99% of manual trans, where you fill the oil to till it starts coming out the fill hole?? This make is easy to know if you have the right amount of oil.
IMO, you should not have to worry about changing the oil, in a new car, with a new transmition. If you are concerned maybe Mal Wood could shed some light on this. He is a site sponcer too!
  • It's not a MKI!
No, it's not the same as 99% of all manual transmissions.
In the workshop manual there is a specific fill procedure where you don't even use the fill plug. You have to fill the box with a measured amount of oil through the reverse switch hole.
The I6 is 4.85L and the v8 3.85L. Why this is so, is not something I cna answer, but it is in black and white on the workshop manual page number I quoted in the other thread.
The funny thing is, in the manual there are heaps of photos of someone disassembling a transmission using a rattle gun. There is a special note from Ford saying they do not endorse the use of air tools for this task and the pictures are from the manufacturer of the transmission and used for illustration purposes.dontknow.gif
Well there you go! I am a Qualified Mechainc, but not on the tools now, seems if you snooze, you get left behind! :buttrock:
I gotta say why car manafacturers make it so complex is beyond me. "Fill till the oil comes out" worked fine for 80 years!
Having said that, I have worked auto cars that have had VERY pacific ways of checking oil. No more KISS for cars! (KISS= Keep It Simple Stupid!)
  • Member For: 17y 4m 13d
A new one on me also.
A way to sell more parts to the unwary and to get you to go to the supposed expert dealerships...... :dontknow:
Fill through the reverse switch hole......what rubbish from the design team at Tremec, particularly after leaving a usual fill plug there. Changing the case mould to do it properly is not that hard. FAIL.
Sounds to me like a post design in situ "fix" to save their bacon.
Edited by Smoke them tyres
  • Banned
  • Banned
hehe, (design office talk....) so guys, where's the oil filler hole ? eh, oh, hmmmm ahh ......well, you fill through the reverse switch right there , see ! :dontknow: yeah.....ok then , good job ! :beerchug:
  • Member For: 15y 3m 17d
I actually also states a measurement from the reverse switch hole to the top of the oil, which I dont see how you could measure it. Think it was either 10 or 25mm cant remember off top of head.
But as stated earlier it is a quantity of 4.85 for the I6. I wonder if the fill hole is useful for a different vehicle when the trans might be in a funny angle.
  • Member For: 14y 8m 22d
Thanks for the information.....
Any chance you can confirm what the measurement for the correct fill of oil is? Otherwise I will bring it back and have them drain the oil and check it....
Though I can just imaging the way that that conversation will go:
Me: I would like you to check the oil level in the gearbox
ford: OK
come back to pick up car....
me: did you check oil level
ford: yes:
me: what was it?
ford: OK
me: so if I check it myself will be OK
ford: sure
when I get home:
Drain oil and find that it is low.....at this point I am sure that Ford will not pay for the replacement oil!!!
