Guest XR09 Guests Posted 18/10/10 11:15 AM Share Posted 18/10/10 11:15 AM (edited) Sounds like it's only happening under a heavy load. Is it a constant sound ???... or Oscillating, as in like a wheel bearing noise ??? Or a groanish sound as the suspension loads up ???An FG should not blow a wheel bearing so soon, but that does not mean it wont. Upper control arm or radial bush perhaps ??? Sway bar mount ??? Splash panels all in place and secure ???? Love my Teins. They take ages to break in.... Had mine on for a year now and they are better then new. Once your over about 120kmp/h they start to work and at 160+ the ride is fantastic. Edited 18/10/10 11:19 AM by XR09 Link to comment https://www.fordxr6turbo.com/forum/topic/71120-steering-grinding-under-load/page/2/#findComment-1048666 Share on other sites More sharing options...
Turbo6FG Silver Donating Members 497 Member For: 15y 2m 30d Gender: Male Posted 18/10/10 12:50 PM Author Share Posted 18/10/10 12:50 PM Not a groaning sound. It's quite constant, like a dentists drill but deeper. Ggggggggggggg & you get the vibration thru the steering wheel.Dunno about the Fords but when the wheel bearing went on my old mans SR5 Hilux it was more of a deep rumble than what this sounds like. That was woobawoobawooba. (like 50 cent doin da rap)Lol I hope nobody reads this post out loud. Everyone will think they've been on the cones with all the noises. Link to comment https://www.fordxr6turbo.com/forum/topic/71120-steering-grinding-under-load/page/2/#findComment-1048720 Share on other sites More sharing options...
ScatterBrain Donating Members 316 Member For: 16y Gender: Male Location: Brisbane Posted 18/10/10 01:14 PM Share Posted 18/10/10 01:14 PM You said you had 19' what width and offset are they? They could be scraping the hub carrier. Link to comment https://www.fordxr6turbo.com/forum/topic/71120-steering-grinding-under-load/page/2/#findComment-1048724 Share on other sites More sharing options...
Turbo6FG Silver Donating Members 497 Member For: 15y 2m 30d Gender: Male Posted 18/10/10 02:59 PM Author Share Posted 18/10/10 02:59 PM 19x9 front 19x10 rear. Did it with the eBay dark argents too though. Link to comment https://www.fordxr6turbo.com/forum/topic/71120-steering-grinding-under-load/page/2/#findComment-1048729 Share on other sites More sharing options...
Jman The Cleaning Dudes Ute Silver Donating Members 1,308 Member For: 19y 1m 20d Gender: Male Location: Bentleigh, Vic, Australia Posted 18/10/10 04:09 PM Share Posted 18/10/10 04:09 PM I had a similar problem with my BF.Turned out one of my swaybar links were bent and caused the swaybar to lean towards the passenger side disk.On full load it would rub up against it. In the end I replaced both swaybar links with upgraded ones to THEN find out the swaybar I bought off the forums was bent lol. Changed that also and problem solved.Hope that helps...Does it happen both sides or only one? Link to comment https://www.fordxr6turbo.com/forum/topic/71120-steering-grinding-under-load/page/2/#findComment-1048734 Share on other sites More sharing options...
Turbo6FG Silver Donating Members 497 Member For: 15y 2m 30d Gender: Male Posted 18/10/10 10:36 PM Author Share Posted 18/10/10 10:36 PM I reckon you are on to something Jman. It does it both ways but worse turning left. Lol maybe they are both bent.Sounds like a trip to WA Suspensions is needed. Link to comment https://www.fordxr6turbo.com/forum/topic/71120-steering-grinding-under-load/page/2/#findComment-1048751 Share on other sites More sharing options...
Guest XR09 Guests Posted 19/10/10 03:46 AM Share Posted 19/10/10 03:46 AM Just noticed you have 19 x 9 on the front. How did you get them in there ??? lolI am running 19 x 8.5 with a 245 front and it misses the upper control arm bolt by 3.5mm. Turn you wheel to the right and stick your head in behind the left wheel and see if there are rub marks.Here's a pic to show you where I mean. Link to comment https://www.fordxr6turbo.com/forum/topic/71120-steering-grinding-under-load/page/2/#findComment-1048792 Share on other sites More sharing options...
Turbo6FG Silver Donating Members 497 Member For: 15y 2m 30d Gender: Male Posted 19/10/10 05:14 AM Author Share Posted 19/10/10 05:14 AM It was a tight squeeze but they managed it. They had to go from 255 down to 245 tyres as the 255 juuuust touched on the control arm. I have about the same amount of room as you've got there.I checked the rim (couldn't actually get my head behind there even with the wheel fully locked round so I felt the edge of the tyre & rim & stuck the camera in & took a few pics). There is no sign of wear/scraping on the rim or tyre edge. It also did the same thing with my old rims (eBay dark argents) so it's gotta be something else.Thinking about it, it's actually got quite a bit worse since I first noticed it a few months back. It was quite rare then, now it happens all the time. Link to comment https://www.fordxr6turbo.com/forum/topic/71120-steering-grinding-under-load/page/2/#findComment-1048812 Share on other sites More sharing options...
bradles024 Donating Members 1,145 Member For: 15y 6m 18d Gender: Male Posted 19/10/10 05:21 AM Share Posted 19/10/10 05:21 AM On 18/10/2010 at 8:53 AM, Turbo6FG said: It sounds like two robots having sex. Link to comment https://www.fordxr6turbo.com/forum/topic/71120-steering-grinding-under-load/page/2/#findComment-1048813 Share on other sites More sharing options...
Turbo6FG Silver Donating Members 497 Member For: 15y 2m 30d Gender: Male Posted 23/10/10 11:11 AM Author Share Posted 23/10/10 11:11 AM Think I've finally found the problem. With the 4" dump coming off the turbo it's pushing the heat shielding out about 1mm away from the steering column. It's just close enough so that when there's a bit of g-force on the car it flaps a bit & starts wobbling (it's probably only got about 5mm give so just enough to make a noise). The heat shielding is still wrapped around the turbo properly so it's not a serious problem luckily, just an annoying one. Might have to tighten it up somehow & see if it's fixed it. Link to comment https://www.fordxr6turbo.com/forum/topic/71120-steering-grinding-under-load/page/2/#findComment-1049971 Share on other sites More sharing options...
