Bonjaz Donating Members 1,841 Member For: 16y 4m 26d Gender: Male Location: CQ Posted 14/10/10 02:05 AM Share Posted 14/10/10 02:05 AM Power = Current x Voltage less current or voltage and your going to get less power output and depends how its all wired...but as the others have said I am gonna guess your amp isnt big enough to make the "HECTIC DOOF" your after haha Link to comment https://www.fordxr6turbo.com/forum/topic/71036-twin-sub-in-box/page/2/#findComment-1047532 Share on other sites More sharing options...
Gonadman2 Member 140 Member For: 18y 6m 11d Gender: Male Location: Perth - WA Posted 14/10/10 05:14 AM Share Posted 14/10/10 05:14 AM On 14/10/2010 at 1:48 AM, straughsberry said: Facing subs toward the front will most likely reduce the amount of bass but experiment. Sealed enclosures are really about SQ and are not the best design for bass volume. A ported box will product a lot more bass and 10 inch drivers do not play as low as a 12 or 15.How low a driver plays is down to Fs (resonance frequency) and not driver diameter. Adire Audio Tumult 12, has a lower Fs than almost every car audio sub on the market.Ported enclosures are more efficient above the port frequency, but less so below it. If you have a ported enclosure it will generally produce more bass below 50hz - port frequency than a sealed setup, at the expense of group delay (kind of like speed). Sealed designs are generally easier to get right, more forgiving to construction and design tolerances, at the expense of roll off. Sealed designs tend to follow the natural increase in bass that you get from a car, resulting in cleaner, more linear sub bass and better integration with the front speakers. Link to comment https://www.fordxr6turbo.com/forum/topic/71036-twin-sub-in-box/page/2/#findComment-1047568 Share on other sites More sharing options...
Dillz Three pedals are better then two.. Donating Members 15,637 Member For: 17y 11m 8d Gender: Male Location: Melbourne Posted 14/10/10 07:01 AM Share Posted 14/10/10 07:01 AM I've only got a cheap system in mine atm, 140RMS 2 channel bridged running a 1300w 12inch in a ported box and bass is more then enough. In the car that is, not that loud out of the car.It's easy to get loud bass but as someone said before if you want a quality sound you gotta pay for it. Oh and mine sits right in the middle facing the front, worked best in my car. Link to comment https://www.fordxr6turbo.com/forum/topic/71036-twin-sub-in-box/page/2/#findComment-1047601 Share on other sites More sharing options...
MY ROD GOT OUT Member 434 Member For: 14y 8m Posted 14/10/10 09:10 AM Author Share Posted 14/10/10 09:10 AM wow!! thanks for the replys everyone. ok so I'd better clarify a few things.amp that powers subs = ECLIPSE DA6213 (500WX2)amp that powers speakers= ECLIPSE 36401 (50X4)headunit = JVC KD-R905its set up with 2 sets of rca's. 1st set runs to sub amp 2nd set runs to speaker amplike I said before power cable is run to sub amp first and looped to second amp. the DA6213 apparently draws alot of powerso maybe looping the power from it to the speaker amp is draining all of its power????thanks again u guys rock!!tim Link to comment https://www.fordxr6turbo.com/forum/topic/71036-twin-sub-in-box/page/2/#findComment-1047652 Share on other sites More sharing options...
XXRLNT TURBOCHARGED Member 372 Member For: 19y 18d Gender: Male Location: MELBOURNE Posted 14/10/10 10:44 AM Share Posted 14/10/10 10:44 AM disconnect 1 sub and see how it sounds. The negative positive wires for the sub might be the wrong way around make sure the negative positive wires are the rite way around. Link to comment https://www.fordxr6turbo.com/forum/topic/71036-twin-sub-in-box/page/2/#findComment-1047680 Share on other sites More sharing options...
MY ROD GOT OUT Member 434 Member For: 14y 8m Posted 16/10/10 07:59 AM Author Share Posted 16/10/10 07:59 AM On 14/10/2010 at 10:44 AM, XXRLNT said: disconnect 1 sub and see how it sounds. The negative positive wires for the sub might be the wrong way around make sure the negative positive wires are the rite way around.I checked all connections they seem ok..... I might run another power cable to the sub amp and see what happens... because in theory my amp is strong enough????? Link to comment https://www.fordxr6turbo.com/forum/topic/71036-twin-sub-in-box/page/2/#findComment-1048061 Share on other sites More sharing options...
seduced Need more power. Now taking donations. Member 753 Member For: 16y 2m 7d Gender: Male Posted 18/10/10 03:56 AM Share Posted 18/10/10 03:56 AM What subs? Ohm ratings? That amp will be only 250wx2 at 4ohms. 500wx2 at 2 ohms. 1100wx1 bridged at 4ohms.Packs plenty of punch, depending on your sub specs, you might be better running one sub on the bridged setting. I am assuming you are running 4 ohm subs, which would only give you 250w in this case.So what model are the subs? Link to comment https://www.fordxr6turbo.com/forum/topic/71036-twin-sub-in-box/page/2/#findComment-1048462 Share on other sites More sharing options...
MY ROD GOT OUT Member 434 Member For: 14y 8m Posted 18/10/10 04:40 AM Author Share Posted 18/10/10 04:40 AM On 18/10/2010 at 3:56 AM, seduced said: What subs? Ohm ratings? That amp will be only 250wx2 at 4ohms. 500wx2 at 2 ohms. 1100wx1 bridged at 4ohms.Packs plenty of punch, depending on your sub specs, you might be better running one sub on the bridged setting. I am assuming you are running 4 ohm subs, which would only give you 250w in this case.So what model are the subs?hey mate, the subs are clarion sw1251 subs, 4ohm by the looks of it..... continuous power 250watt peak 700watt...should go hard in theory??? Link to comment https://www.fordxr6turbo.com/forum/topic/71036-twin-sub-in-box/page/2/#findComment-1048482 Share on other sites More sharing options...
kink Member 294 Member For: 16y 8m 29d Gender: Male Location: Adelaide Posted 20/10/10 11:18 AM Share Posted 20/10/10 11:18 AM my 12inch sub box doesn't fit under the parcel shelf :( let alone both.... Link to comment https://www.fordxr6turbo.com/forum/topic/71036-twin-sub-in-box/page/2/#findComment-1049203 Share on other sites More sharing options...
