Redback Banned 236 Member For: 15y 10m 6d Gender: Male Location: Blacktown NSW Posted 09/11/10 09:53 AM Share Posted 09/11/10 09:53 AM Anyone know where I can order the idle pulley bearing online? I pulled it off and repacked it but the seals on the bearing were all cracked and breaking up. Little bits of plastic where falling off everywhere. I put it back together but I want to replace it for a new if its only $25. Picked up the belt from supercheap for $50. Gonna chuck that on with a new bearing. How long does a belt usually last? I just thought I would replace because its done 100K and is 7 years old now.If you use a socket you can push that bearing out and get one for about $5 from a bearing shop. As you can tell I like to repair things the old fashion way. But for effort free replacement buy a genuine. If you call ford they'll order one for you you dont need part numbers... Link to comment https://www.fordxr6turbo.com/forum/topic/70993-squeaking-noise-from-engine-pullybelt/page/3/#findComment-1054387 Share on other sites More sharing options...
freeze_dk I am dissatisfied with my current employment situation Donating Members 8,610 Member For: 18y 6m 20d Gender: Male Posted 09/11/10 10:24 AM Share Posted 09/11/10 10:24 AM is the idle pully easy to change for a DIY? Link to comment https://www.fordxr6turbo.com/forum/topic/70993-squeaking-noise-from-engine-pullybelt/page/3/#findComment-1054403 Share on other sites More sharing options...
Redback Banned 236 Member For: 15y 10m 6d Gender: Male Location: Blacktown NSW Posted 09/11/10 10:48 AM Share Posted 09/11/10 10:48 AM Yeh its not hard at all mate. Link to comment https://www.fordxr6turbo.com/forum/topic/70993-squeaking-noise-from-engine-pullybelt/page/3/#findComment-1054418 Share on other sites More sharing options...
rule1110 Member 71 Member For: 16y 11m 16d Posted 10/11/10 07:51 AM Share Posted 10/11/10 07:51 AM I changed both pulleys (idle and tensioner) today and was pretty easy to do. Pulleys and bearings were $25 and $31 from repco and I also put a new belt on which I'm glad I did because I found a decent crack in the old one. This link was handy as it tells you how to replace the belt. I took the fans out like he says too and it makes it much easier.BA Falcon drive belt replacement Link to comment https://www.fordxr6turbo.com/forum/topic/70993-squeaking-noise-from-engine-pullybelt/page/3/#findComment-1054645 Share on other sites More sharing options...
