Spoony Member 250 Member For: 14y 6m 14d Gender: Male Location: Brisbane Posted 15/11/10 09:18 PM Share Posted 15/11/10 09:18 PM dynamat is my next thing. I did notice just how flexible the shelf is though (grab the back of the sub and can move it/shelf a fair bit, the fact the driver is quite heavy to prob dont' help). This would likely be more of an issue once better amped(powered) but wouldn't be helping eitherway. Dynamat probably wont help here much but short of bracing the shelf probably not much can do. No I need to work out what front speakers. I've read only good things about these Shopping Secure - Car Audio Specialists - SPL Dynamics SD-6.2 expecially for the price. Might put the std front speaker split setup in the rear. While obviously still crap, seem much better than what is in the rear standard? Link to comment https://www.fordxr6turbo.com/forum/topic/70899-direct-replacement-aftermarket-subwoofer/page/3/#findComment-1056127 Share on other sites More sharing options...
FAT-51X Member 254 Member For: 20y 11m 17d Gender: Male Location: Newcastle Posted 17/11/10 09:56 AM Share Posted 17/11/10 09:56 AM I to am contemplating the replacement option.. My local Autobarn just took delivery of a Kenwood 8" Excelon KFC-XW800F specs as follows:Size 8 -inchImpedance 4 ohmsCone Material Carbon-glass fiberSurround Material Butyl rubberSealed Box Volume (cubic feet) 0.5Ported Box Volume (cubic feet) 0.5Port diameter (inches) 1.1875Port length (inches) 11Dual Voice Coil NoSensitivity 78 dB at 1 voltFrequency Response 40 - 500 HzRMS Power Range (Watts) 50-150Peak Power Handling (Watts) 600Mount Depth (inches) 2 3/4Cutout Diameter or Length (inches) 7 3/16Vas (liters) 10.7Fs (Hz) 43Qts 0.812Xmax (millimeters) 6.5Now I have no idea about what all this means hence why im looking for opinions from u guys..Thoughts??? Link to comment https://www.fordxr6turbo.com/forum/topic/70899-direct-replacement-aftermarket-subwoofer/page/3/#findComment-1056641 Share on other sites More sharing options...
Spoony Member 250 Member For: 14y 6m 14d Gender: Male Location: Brisbane Posted 17/11/10 10:11 AM Share Posted 17/11/10 10:11 AM That should work ok, not overly efficent but it appears to be designed by lower powered amps. + with a Qts value of .812 it should work well free air. Link to comment https://www.fordxr6turbo.com/forum/topic/70899-direct-replacement-aftermarket-subwoofer/page/3/#findComment-1056644 Share on other sites More sharing options...
Spoony Member 250 Member For: 14y 6m 14d Gender: Male Location: Brisbane Posted 01/12/10 12:12 AM Share Posted 01/12/10 12:12 AM I 'bogan spec' sound deadend the parcel shelf last night (using FlashTac, already has some so why spend $'s on Dynamat). I've still gotta redo my 8 to 10'inch MDF spacer as its no 100% atm, but as other have said, Dynamatting the parcel shelf does help and is noticable. Link to comment https://www.fordxr6turbo.com/forum/topic/70899-direct-replacement-aftermarket-subwoofer/page/3/#findComment-1059857 Share on other sites More sharing options...
spook Donating Members 180 Member For: 17y 21d Gender: Male Posted 01/12/10 07:40 AM Share Posted 01/12/10 07:40 AM Good to hear it made a difference for you also. Glad I'm not imagining things. Link to comment https://www.fordxr6turbo.com/forum/topic/70899-direct-replacement-aftermarket-subwoofer/page/3/#findComment-1059946 Share on other sites More sharing options...
1600dave Donating Members 872 Member For: 14y 3m 15d Posted 02/10/11 12:21 AM Share Posted 02/10/11 12:21 AM On 02/11/2010 at 4:24 AM, tim85 said: Well I must say I am very happy with my Polk. I just need to dynamat the parcel shelf now.Tim,With the MM840DVC, how do you have the voice coils wired, series or parallel?I didnt think the stock amp would handle a 2ohm load too well, but if yours is still going, might have to give it a go.Might be why the Polk performs too, as the amp would be putting out more power that way.If in series (giving 8ohms) I'd imagine it'd sound worse due to the low power it'd be getting.They do make a single voice coil 4ohm model too. Link to comment https://www.fordxr6turbo.com/forum/topic/70899-direct-replacement-aftermarket-subwoofer/page/3/#findComment-1145651 Share on other sites More sharing options...
brownhornet Donating Members 124 Member For: 16y 9m 6d Gender: Male Location: Perth Posted 15/10/11 11:30 PM Share Posted 15/10/11 11:30 PM I've just put in a Rockford Fosgate Punch P1S4 8" Subwoofer. Bolted straight in without any mods. I also dynamatted the rear shelf.Very happy with the results. Massive improvement over stock.While I was at it I also replaced the front speakers with some Alpine Type-S 5x7s. Again, a big improvement.All up, for about $300 (including a sheet of dynamat) the stock premium audio has been transformed into something listenable. Link to comment https://www.fordxr6turbo.com/forum/topic/70899-direct-replacement-aftermarket-subwoofer/page/3/#findComment-1149848 Share on other sites More sharing options...
1600dave Donating Members 872 Member For: 14y 3m 15d Posted 18/10/11 08:49 AM Share Posted 18/10/11 08:49 AM On 15/10/2011 at 11:30 PM, brownhornet said: I've just put in a Rockford Fosgate Punch P1S4 8" Subwoofer. Bolted straight in without any mods. I also dynamatted the rear shelf.Very happy with the results. Massive improvement over stock.While I was at it I also replaced the front speakers with some Alpine Type-S 5x7s. Again, a big improvement.All up, for about $300 (including a sheet of dynamat) the stock premium audio has been transformed into something listenable.Replaced the fronts including the tweeters in the pillar?How'd ya wire it if so? Link to comment https://www.fordxr6turbo.com/forum/topic/70899-direct-replacement-aftermarket-subwoofer/page/3/#findComment-1150879 Share on other sites More sharing options...
brownhornet Donating Members 124 Member For: 16y 9m 6d Gender: Male Location: Perth Posted 18/10/11 11:31 AM Share Posted 18/10/11 11:31 AM For some reason my premium audio was missing the tweeters in the A pillar - not sure why. The Alpines were a straight swap for the stockies. Link to comment https://www.fordxr6turbo.com/forum/topic/70899-direct-replacement-aftermarket-subwoofer/page/3/#findComment-1150995 Share on other sites More sharing options...
1600dave Donating Members 872 Member For: 14y 3m 15d Posted 19/10/11 06:28 AM Share Posted 19/10/11 06:28 AM Strange. Mine didnt have a sub (but had the amp) although it was ex pig spec.The stock tweeters are pretty sh*t anyway.So you have tweeters now? Used the Alpine crossovers and ran your own wiring? Link to comment https://www.fordxr6turbo.com/forum/topic/70899-direct-replacement-aftermarket-subwoofer/page/3/#findComment-1151288 Share on other sites More sharing options...
